wiring question
Old 09-25-2010, 10:18 PM
nunan0219's Avatar
Default wiring question
i have a pull out from a 98 camaro, and i have a few questions. if i'm running a th400, what wires for the manual trans can i get rid of?
also, the harness that goes through the firewall grommet, what do i need out of that? all i have is the pinouts and my chiltons book, but it doesnt say what connector numbers those are.
thanks
Old 09-26-2010, 09:50 PM
luigiandme's Avatar
Well since a TH400 has no 'compatible' wiring hookups to your harness. None will be of use. If you plan on using the stock speedometer, you need the wheel and pickup mod for the th400.
http://www.transmissioncenter.net/sp...n_______va.htm
About 3/4 of the way down, you'll see a second called TH400 Speedometer Parts. Item #64.
Quick Reply: wiring question
