LS4 Performance - MSD Igntion
tmichelena
09-25-2010, 11:34 PM
Hey guys,
Anybody here run the MSD ignition coil package and have any feedback? I know Mel does...not sure it's worth the $669?
Thanks,
Tom
D J Real
09-25-2010, 11:47 PM
Hey guys,
Thanks,
Tom
I've gone back and forth with this to, but i ended up going against it. While G.M. did cut a few corners in making these cars, one area they did not skimp on was the ignition system. To the best of my knowledge its actually a pretty good system stock and messing with it doesn't really give any real gains. Certainly not ones that would justify spending that sort of cash IMHO.
dcrews
09-26-2010, 12:30 AM
Search around here for the truck coil upgrade. Seems to be the way to go if you wanted to upgrade
neilownz
09-26-2010, 12:39 AM
Accel makes some too. Waste of money imho.
Mels SS
09-26-2010, 06:46 AM
I just have the MSD ignition plug wires the stock coils are hot enough. The wires are the issues and a lot cheaper than than coils and the truck coil are a waste there just as hot.
06MonteSS
09-26-2010, 10:33 AM
yeah... don't do it man...
you'll end up introducing problems when you don't have any to begin with... don't need the MSD stuff at all.... stock with stockers!!
have seen a lotta people have issues after they installed the MSD stuff...
Nemesis350
09-26-2010, 11:17 AM
Sorry, i have nothing against msd, but everyone i know that has boughten their coils packs for the ls have had them fail at some point.
If you want anything other than stock (which aren't bad at all) you should find the round truck coils deemed D585. They're said to have better output top end, are the preferred choice of forced induction setups, and usually don't cost anymore than $150 for a full set on brackets with wiring harness.
If you want anymore detailed info, put d585 in the search, and read up on the plentiful info. ;)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
