6.0 block with l92 heads
My valve train is making a bunch of noise, I have a 6.0 truck block(408cbi) with l92 heads a comp lsR cam with I- .620 lift, E-.618 with a 235/231 duration on a 115lsa I used my pushrods from my ls1 and they are comp 7.400 hardened push rods and the lifters are Ls7, and im using stock rocker arms. With l92 heads should I be using a diffrent length pushrod? or does anything stand out that might make it so loud? I remember my cam only ls1 being loud but this seems louder.
Thanks Jim
Thanks Jim
LS1Tech Premium Sponsor
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
