Need help from someone who still has EGR!!
Needing someone who still has egr installed on their car. I need pictures of the electrical connectors and the colors of the wiring to each connector.
Reason being, I am tracking down a lost tachometer signal, and someone said there is a plug near the egr that has a male/female side that needs to be plugged in to get the tach to work again. We cut all these wires out when we removed A/C and EGR, so I need to know which ones attach together etc.
I have the wiring harness completely apart on the passenger side of the car ready to go with connecting the wires I need to get the tach to work.
Here's the original thread discussing the problem and someone suggesting to do the connector thing.
https://ls1tech.com/forums/pcm-diagn...l#post13920206
Quickness would be appreciated thank you!!
