Swap Pins in PCM so Rear O2s work like Fronts?
I've searched and read multiple threads about this but I'm still confused on what to do. Does anyone have any pictures of the connector that holds the pins need to be switched? Really don't want to spend money on extensions if I have to.
You want to do what!
I've never read anything about doing this...why would you want to rig the rear o2's to run like the front o2'? The front oxygen sensors work just fine as a pair.
IMO, the best way to handle the rear o2's is to removed both rear sensors, install an 18mm plug in each hole, have the rear O2 codes turned off by your tuner.
A clean and professional mod.
You just need to remove the front 02 wiring pins and insert the rear 02 pins in there place.
move the pin on Blue 25 to Blue 26 for bank 2
move the pin on blue 28 to Blue 29 for bank 1
If you want to clean up your harness a bit you could just remove the front 02 wiring.
I just finished installing headers and I read that you can swap pins in the PCM so that I can plug my front o2 sensors into the rear connectors and the PCM will use them for fuel trims. Seems like a cheap alternative to buying extensions or new o2 sensors, I'm just not sure how to do it.
Never thought of that. Thats a great idea.
I looked at the PCM and there is a gray cover on the top of it with two bolts that look like it's holding it on. Is the Blue connector under there?
[/QUOTE] I'm clueless when it comes to the wiring harness or anything physically on the PCM. I'm not sure where the Blue 25, 26, 28, and 29 are
I looked at the PCM and there is a gray cover on the top of it with two bolts that look like it's holding it on. Is the Blue connector under there? [/QUOTE]
There are two large connectors that plug into the PCM. The top one is the blue connector and the bottom is the Red. There is a 7mm bolt holding the plugs into the PCM. Unbolt the top one(blue) and the plug in will come out when you thread out the bolts.
The grey plastic retainer on the back of the blue connector must be removed to expose where the numbers for the pins are located. The numbers are very tiny and are beside where each wire comes out of the plug.
On the inside of the blue connector there is blue plastic caps(hence why they call it the blue connector) that cover the pins. Remove these by using a small pick on the sides and these will simply pop off. Once these are off you can now lift up gently on the tabs holding in the pins and pull them out the back.
This probably looks very confusing but, I promise if you take off the connector and look at it, this will be very easy. Good Luck
I have a '99 TA and that sounds fairly straight forward actually. I'll take a look at it after work and see if I can figure it out.
Also, I've been reading on here and I see where some people say there is no difference between a front o2 sensor and a rear o2 sensor. I've also seen where some people say there is a difference. Not sure which one to believe but the pairs look identical. Does anyone know for sure if the front o2s and rear o2s are interchangeable?
[QUOTE=Golf&GM;13922752]I have a '99 TA and that sounds fairly straight forward actually. I'll take a look at it after work and see if I can figure it out.
Also, I've been reading on here and I see where some people say there is no difference between a front o2 sensor and a rear o2 sensor. I've also seen where some people say there is a difference. Not sure which one to believe but the pairs look identical. Does anyone know for sure if the front o2s and rear o2s are interchangeable?[/QUOTE]
yes they are. the only different is the wire lenght. an O2 sensor is an O2 sensor.
to the OP did it work with you? if not i got some info that i can look for if you need them.
Forgot to mention that I also swapped a few more pins just to be on the safe side. All in all I switched:
25 HO2S Low Signal [Bank 2 Sensor 2]
with
26 HO2S Low Signal [Bank 2 Sensor 1]
28 HO2S Low Signal [Bank 1 Sensor 2]
with
29 HO2S Low Signal [Bank 1 Sensor 1]
65 HO2S High Signal [Bank 2 Sensor 2]
with
66 HO2S High Signal [Bank 2 Sensor 1]
68 HO2S High Signal [Bank 1 Sensor 2]
with
69 HO2S High Signal [Bank 1 Sensor 1]
Those were all the O2 sensor pins I saw on my '99 pinout sheet.
with
with
with
with
Sorry it's taken so long, I hooked it up to my scanner and deleted the rear o2 (sensor 2) codes and the EGR/AIR codes.
O2s are switching correctly and it's adjusting fuel trims beautifully. I haven't had any codes thrown in the past week or so and I've been driving it everyday.
Just saved a good chunk of money and time by just swapping pins, thanks for the help!
