Header Info, Again
Header Info, Again
Getting ready to throw on some Pace Setter LT's on my 93, I know they have their supporters and haters here but I got them for a deal and I am using them.
I already have the Fel-Pro gaskets to go in place of the junky ones they come with, Stage 8 locking bolts, poly motor mounts, new O2 sensors, O2 conversion harness, and plugs/wires. Anything else I need? What about some heat shielding around the plug wires or anything else?
I also ordered the Summit Universal X-pipe kit and I plan on making my own system behind the headers. Anyone who has used this kit and has some photos or tips would be very welcome.
Also if anyone can throw up the link to the header install I would be great-full, I've searched and can't find the big install thread.
Village Troll
Get rid of the Stage 8 locking bolts. They are a huge bitch to use and not necessary. Go with an ARP bolt instead. Either a six point 3/8"X1" or equivalent. They will not back out if you torque them correctly.
Here is a link below,I agree with SS RR if they are tightened after a couple of heat cycles they will be good to go.Mine have stayed tight for a year and a half.
I used stock manifold gaskets on my headers and I have not had any leaks.I tried stock gasket back fifteen years ago on my old nova,because it would blow every other type gasket out.
http://www.97ta.com/flp_header.shtml
I really don't wanna ditch the Stage 8 bolts, I bought them so long ago now that I can't send them back, so I might as well use them. Worst case scenario if I can't use the locking tab they will still work as a normal fastener right?
That install guide will be a good help but I thought I remember reading a step by step guide on this site somewhere too, if anyone can help me in my search.
One last thing I thought of before I take the car apart, what do I need in the way of specialty tools? I have a good selection of tools as it is but what about universals or odd items like that?
I couple of tips from my install a couple weeks ago:
Do the motor mounts one side at a time. After the new mount is in but before you put the middle bolt through, jack the engine up and slide in the header for that side. Get everything bolted up and then repeat on the other side.
The motor mount bolts can be a real bitch to get lined up. I got them fully bolted in before realizing I had to unbolt them to get the headers in. I spent more time messing with the mounts than anything else.
I don't think I had any other major annoyances.
If you have new coated headers, reuse the old O2 sensors for a little while after wards. Apparently the coating does a final cure as the car is run, and can ruin them.
