walbro 255 lph pump
walbro 255 lph pump
what is needed to install walbro 255 pump. do you have to completely rewire or use stock wiring. the reason i ask is some show a wiring kit. also on summitt website which pump or kit would you buy for 1997 firebird lt1.
You don't have to rewire, but running a thicker gauge hot wire will reduce voltage drop to the pump and therefore increase capacity, both with the Walbro and stock pumps.
If you're just replacing the stock pump and not planning on over 400 rwhp, then the stock wiring is sufficient.
