Advanced Engineering Tech - Spark Plug Discussion....serious motor guys what do you think?
quik95lt1
09-28-2010, 03:16 PM
Ok heres a quick rundown of the motor......
its a 385 ci LT1
13.9:1 CR
260/264 .703/.715 106LSA SR Cam
AI 215cc cnc TFS heads
Single Plane Victor E
peak power at 7450rpm
peak torque at 6050rpm
flat power out to 8000rpm
ignition
FAST XFI
MSD 7AL-2
MSD HVC Coil
MSD Crank Trigger
Currently I am running NGK BR7EF plugs and the car runs well, it drives around well with out any issues and makes good power at WOT. However as you all know the BR7EF is a standard tip plug. I bought a set of projected tip plugs to try in the motor. Now knowing that the projected tip is more prone to heat and detonation I went a heat range cooler. They are TR8IX's from NGK. Currently my plug has marks up the first 2-3 threads which from what i understand means the heat range is appropriate. And also my timing mark on the ground strap looks good. It looks as though it is running well......but in the search for more power what do you guys think? Anyone have experience with experementing like this or any info they can add? Trying to learn here and experement for more power!!! Every little bit helps at this point lol...
Thanks,
Mike V
Schwanke Engines
10-20-2010, 11:37 AM
The rule on sparks plugs is colder is safer. I would start with a TR9IX instead of the 8's. If you notice fouling, go to the 8's. It is better to be safe than sorry.
