My guages and tripdometer reset each time I start my car. Any ideas why?
Old 09-29-2010, 07:54 AM
92StangMan's Avatar
Default My guages and tripdometer reset each time I start my car. Any ideas why?
Wasn't sure if this was the proper forum to post in.
Each time I start my car, the tach and speedometer needle will travel all the way to the right and then back to the left where it will settle (tach moves from 0-6,500 RPMs and then back to 500 RPMs when idling). My tripdometer also resets each time too.
I thought it may be a battery issue with a charge but the clock on my CD player never resets and my car doesn't have charging issues.
Any ideas?
Old 09-29-2010, 12:02 PM
OUTLAWZ RACING's Avatar
check the ground on the battery aswell as the + side.
Old 09-29-2010, 11:09 PM
SHovV's Avatar
my car was doing the same then when i got it ( 4th owner ). check your terminals. mine were tight, it ended up being the battery was too weak and not holding a charge
Old 09-30-2010, 08:04 AM
Michael02hawk's Avatar
The 1999 models are well documented at having this problem.
I havent read about this issue on a 2000 model year...but, who knows.
Search and look for the service bulletin.
Old 09-30-2010, 08:29 AM
NXZ28's Avatar
Does the gauge cluster have a small battery in it like a computer in order to save the mileage and trip readings even if you don't have an acutal battery in the car? For example, I stored my Camaro a few years back and completely unhooked the battery. When I reinstalled it 7 months later the actual mileage of the car and trip were the same as when I left it.
Old 09-30-2010, 07:21 PM
Moderator
jimmyblue's Avatar
Crusty connections are a possibility. I had two Delco
batteries in a row ooze acid from the terminals and it
chewed up my connectors pretty badly.
Old 09-30-2010, 07:27 PM
ULTIMATEORANGESS's Avatar
gauge cluster.
