Intake Removal
Intake Removal
Getting ready to put on some LT headers and I am going to address some other items while I'm at it. I plan on replacing valve cover gaskets and intake manifold gaskets is there anything special to be aware of while I'm at it? I will also be replacing as many of the vacuum lines as I can get replacements for. Are the most of them Chevrolet only parts or can I buy the correct size vacuum lines and just cut them to fit?
I will also be changing the oil of course and coolant, what about the thermostat while I'm at it? Anything else I should look at while I'm getting the bloody knuckles already? The opti is only a few months old so it stays for now.
https://ls1tech.com/forums/lt1-lt4-m...oval-swap.html
https://ls1tech.com/forums/lt1-lt4-m...ould-know.html
https://ls1tech.com/forums/lt1-lt4-m...questions.html
https://ls1tech.com/forums/lt1-lt4-m...t-replace.html
https://ls1tech.com/forums/lt1-lt4-m...row-again.html
Most of the hard vacuum lines are very resilient - it's the rubber elbows that eventually start to rot. See what you want to replace, then bring it to a parts store and look through the "help" section.
Changing the thermostat is a wasted expense if yours is fine.
Thanks, I should have searched better. Doesn't look like I need anything special if I pull the whole fuel rail off the intake and inspect and/or replace fuel injector o-rings as necessary.
I was just figuring on pulling the valve covers to give me a touch more room when installing the headers and thought they were a one time use is all.
This maintenance is extremely overdue, the previous owner absolutely destroyed this car and I'm trying to keep it running while improving/fixing it and still driving it. All the vacuum lines look suspicious to me because I can just pull them off with my hands using minimal effort and I have an off idle right now. The idle is probably a combination of a crazy exhaust leak/bad oxygen sensors/vacuum issues.
I posted when I first picked this car up, I pulled 50lbs, no exaggeration of excess wiring and bull$hit out of this car trying to clean it up. I was fooled by the nice paint job, should have known it was covering up an abused interior.
I removed one of my VCs and reused the gasket, its a rubber gasket so unless it is torn or what not you can reuse. Just be sure not to tighten the covers too much you can easily over tighten because the bolt will just keep going until it most likely breaks. BEFORE you remove the covers get an idea of how tight the bolts are, or just follow torque specs if you have a wrench.
As for the vacuum lines you should be able to replace most with generic hoses as long as there are no crazy bends in them, buying ones precut will obviously cost you more in the long run.
I would just get rid of all the junk on the intake if I were you. It's confusing to put back on anyways. Just buy a set of vaccum caps and go to town on it. Delete egr, AIR, EVAP, all that junk. I will look a lot better too. While it's off you can paint it too. They have some colored engine paint at most auto parts stores. It all pretty easy. I would if you're taking it off anyways.
Putting on headers at the same time, so removing EGR, AIR, and EVAP systems. Probably going to loose ABS as well since it doesn't work anyway. Should clean up under the hood a lot and actually make it so I can see a motor once it's all gone.
On the EVAP system did you just put a breather on the line coming out of the gas tank? Did you put it close to the tank or did you put the breather on it under the hood?
Village Troll
Nah. They are a heavy/thick rubber and actually would last as long as the engine. If they are not dried/cracked and you weren't experiencing any leakage then they are easily reusable.
The most important item to remember is to place the intake straight down, don't replace it on an angle you will knock off the front and rear gaskets. Also, you must let the gasket sealant cure for 24 hours before you fire the engine, that step is very critical. Good luck with your mini rebuild.
