Carbureted LSX forum - Finally tuned and dyno'd
LS_10
09-30-2010, 07:12 AM
We finally got it tuned last Thursday night. Made 405rwhp 344rwtq.
http://www.youtube.com/watch?v=3yAN6TWmvyA
DMMizell
09-30-2010, 07:34 AM
sounds good!
LS_10
09-30-2010, 07:48 AM
sounds good!
Thanks!
team39763
09-30-2010, 02:18 PM
That thing sounds mean.
NemeSS
09-30-2010, 03:15 PM
sounds aggressive!
overhere
09-30-2010, 04:49 PM
nice! what does your timing look like?
LS_10
09-30-2010, 07:11 PM
Thanks! If I knew how to post it up on here i would...lol
raymond mckinney
09-30-2010, 07:20 PM
Guess the 5.13's make up for the small stall? Or you plan on spraying it? Reason i ask is my Trex liked a 4500 stall in my camaro.
overhere
09-30-2010, 07:49 PM
open up the msd program and take a screen shot of it. then past it in paint save as pic and upload it.
LS_10
09-30-2010, 08:21 PM
Yep going to spray it. Got a NOS cheater kit just got to find the time to get it on and the stand alone fuels system in and wired up.
LS_10
09-30-2010, 08:29 PM
it's nitrous converter with the anit balloning plate. The gears will be changed before being sprayed things happen to fast with 5.13's to spray it with 275 60's
raymond mckinney
09-30-2010, 08:36 PM
Cool. My Trex set-up in my old 346 loved the spray! Yours should run low 10's on a small shot.
ZONES89RS
10-01-2010, 07:05 AM
What size were you going with LS 10? I am going to hit mine with a 150(that is as big as my 100$ swap meet kit goes to).
NemeSS
10-01-2010, 02:21 PM
trex cam responds very well to even a low dose of spray 100-150 hit
LS_10
10-01-2010, 04:33 PM
i'm going to start with a 150 if i like that i'll get a progressor and go to 200 and maybe 250 just to see what happens with it being progressed. Might go BOOM! I have now doubt it will go low 10's it should go 10's on motor once i change the gears and don't have to let off just past the 1/8. We did an 86 notch with pretty close to the same set up on a 250shot leaving at 20% with a 3sec build time and went 9.60 @ 147 back to back. My motor makes more power than the one it the mustang tho. It was fuel injected as well with a vic jr. intake same cam
LS_10
10-01-2010, 04:36 PM
I've been 6.90 @ 101.9 and 11.18 @ 98 that was last spring now that we got it tuned and dropped a little more weight off it should run a bit quicker i'd think
NemeSS
10-01-2010, 05:46 PM
ive run 200 dose thru my trex equipped car, and let me tell you.
boy, howdy. its scary good mofo feeling.
maybe not so fun for the passanger
:D
LS_10
10-01-2010, 05:59 PM
:D
Nice! Did you hit it straight up or with a progressor?
raymond mckinney
10-01-2010, 08:30 PM
I hit mine with a 150-200 hit for 5 years sprayed dead out the hole.
LS_10
10-01-2010, 11:35 PM
maybe I'll try that instead of buying a progressor...my bottom end is fairly fresh with good rod bolts. If it blows up i can build the 408 i've been thinking about...lol
ZONES89RS
10-02-2010, 12:59 AM
It will hold on the bottom, it is stock pistons that can give up, but a 200? Naaa, they are good for it.
