LPP Ground Clearance?
Since the big LPP thread apparently got killed, I can't seem to find too much info on the LPP headers, like ground clearance pics/info for instance. How does the ground clearance of the LPP headers compare to other longtube headers like Pacesetter, Hooker, etc.? Does anyone have any ground clearance pics on a slightly lowered car (I have Konis w/ stock springs on the lower perch up front, and hose mod out back).
They should offer the same clearance as Kooks. I would guess Kooks probably have the best clearance of any widely available LT1 header.
My car has qa1 coilovers up front and eibachs out back with qa1 adjustables and i have prolly 3-4 inches of clearance
Camera is sitting on the ground so may look like more cleareance then it has
The roads are absolute garbage out here, and I have many large speed bumps in my condo complex. It's for a daily driver. I originally wanted to do midlength headers, but the ports on the RK Sports don't line up with the exhaust ports on the ported heads I have and the AS&M headers which should line up properly seem to be very difficult to find. I've got a set of LPPs on the way and since they seem to tuck up much nicer than the Hooker LTs I've had in the past I don't think I'll have too many problems if I'm careful.
having said that, my torque arm mount is lower and that's what usually hits every speed bump.
