Anyone mod their water pump??? Need advice.
Old 10-02-2010, 07:29 PM
Marcello7x's Avatar
Default Anyone mod their water pump??? Need advice.
So i had no idea what hoses to use to connect my pump to my radiator. So i figured i'd just pick up the hoses that where ment to go with my engine. I got silverado upper and lower from an auto parts store. The upper i can use, i'll only be using about 1/4 of it, but the bends work in my favor. The bottom is killing me.
Worse come to worse i can have my radiator outlet cut and rewelded at work, but i still need some sort of 90 bend on the water pump outlet.
What can i use? Is there something i can pick up at home depot??
I really want to get the motor running tomorrow. So any ideas are appreciated. Also if you have pics or know of some other threads that may help me feel free, a search didn't help me too much, i must be using the wrong key words since i know i have seen some similar just browsing in the past.
Attached Thumbnails Anyone mod their water pump??? Need advice.-cimg0784a.jpg
Old 10-02-2010, 07:49 PM
ChucksZ06's Avatar
Take a piece of wire and bend it how you need the hose to go to make the corners to connect each end. Take the pattern to auto parts store and ask them to let you look thru their wall of radiator hoses. It is amazing all the different bends the various stock hoses have. I am sure you can find one that will work for the setup you have pictured. You may have to buy a longer hose and cut it down...remember to think outside the box as you look for the right bends.
Old 10-02-2010, 07:58 PM
sierrac3_s2000's Avatar
Bending wire and going to the parts store works great. Worst case is you might have to use two hoses and mate them together for the right shape. There is also a straight thermostat housing for the LS water pump that might make things easier for you.
Old 10-02-2010, 08:38 PM
Marcello7x's Avatar
The angle is pretty extreme. Anyone know if there's a stock one that comes out strait? If someone has a part number that would be better.
Old 10-02-2010, 09:12 PM
https://ls1tech.com/forums/3876896-post14.html
Old 10-03-2010, 02:35 PM
Jimbo1367's Avatar
http://www.csr-performance.com/shop/...-1.5-inch-hose
Old 10-03-2010, 04:19 PM
Rafko's Avatar
Default ......
you can also buy a swiveling thermostat housing to get adjustability so you can use a hose that you find
Old 10-04-2010, 12:28 PM
Nashty's Avatar
Or you can cut the stock thermo housing off at the flange, re-clock it and change the angle and weld it back on.
Check the pictures of mine here:
https://ls1tech.com/forums/conversio...kets-work.html
Old 10-07-2010, 11:36 AM
Marcello7x's Avatar
Exactly the kind of thing i was looking for. My only issue is i don't have a tig. Might buy one over the winter, but for now i found a nice hose that sorta works, and im having my radiator inlet/outlet?[by the way which end does the pump flow out from???] Clocked to work. Thing is we're so busy here at work its been sitting in the welding area since monday, our welder said he's going to try and get it done tomorrow so i have it for the weekend.
I'm PM'n you a question about AC clearance from that thread.
Old 10-08-2010, 09:12 PM
Nashty's Avatar
PM'd back.
I had a friend weld mine up. Sadly, a TIG is on my wish list but constantly stays at the bottom.
Quick Reply: Anyone mod their water pump??? Need advice.
