switching to 98-02 brakes
For the fronts,ls1 spindles,rotors and cailpers all from a ls1 car.
For the rear,ls1 backingplates,rotors and cailpers.
Just unbolt brake line from the back of the cailper. don't miss with the hardlines. Thats about it!
Front:
Remove ball joints,tie rod ends brake line from body and the abs wiring remove entire assembly from donor car
Rear:
E-brake cables,brake line from car to housing,housing to calipers....Open rear cover disassemble rear,pull axles and remove backing plates,calipers and rotors. dont forget the e-brake cable brackets...
Rear:
Damn! I wanted to do the rear brake swap, but screw it if I have to remove the axles out of the rear...
Remember that some LS1 guys switch to LT1 brakes in the rear so its easier to clear drag rims.
So if you plan on running them in the future you might wanna stay with your stock brakes in the rear.
There is almost no benefit to going to an LS1 rear brake. The front brakes are slightly better and the calipers are lighter so it's a cheap way to improve braking and shed a little weight, but for the rears it's useless.
