Wondering if I've fallen victim to my 1st opti failure or otherwise?
Started the car for a friend the other day, let it run for a few minutes, gave her a quick rev, not to the moon just enough for the guy to get an idea of what the bullets sound like, then pow through the exhaust, no start since.
I checked spark on #1 and there is spark there, got plenty of fuel and I have valve actuation although I haven't checked tdc correlation with the valves. Fairly new cloyes double roller though and I find it hard to believe that it's (timing set) my culprit but it could be.
Opti? what you guys think, any similar situations? I know it's cheaper to replace the chain that the dizy but @ the same time, she's sealed up really nice and I hate the thought of crackin her open and having a possible oil leak afterward.
Well, your first steps would be these:
http://shbox.com/1/4th_gen_tech2.html#opti_test
But if you blew the rotor off, you might not see it until you open it up and look.
GOOD THOUGHT, ANYONE TRIED AN OPTI FROM THESE CATS?
http://cgi.ebay.com/ebaymotors/95-96...Q5fAccessories
I know i shouldnt say this, but use the green lock-tite...X)
I talked to Ac Delco a couple days ago and they said they could not find someone to replicate the mitsu sensor good enough. So I don't know what went into that sensor, but it seems to be some serious engineering.
