Anyone have ported head pics they would like to share?
Old 10-05-2010, 11:41 AM
whytryz28's Avatar
Thumbs up Anyone have ported head pics they would like to share?
Since my heads are coming off, figured id try my hand at more porting (done a few Iron heads and intakes) while they are off the car.
Any one have LE or AI pics (not trying to steal from the pros lol just wanna learn) Searched for couple days and couldnt find anything. If you do know where I can find some post the link please.
Thanks
Old 10-05-2010, 12:56 PM
quik95lt1's Avatar
bunch of pics of the AI's here
http://advancedinduction.com/AiProductsLTx.html
awesome head i got the tfs 215cc's they're sick!!!
Old 10-05-2010, 01:01 PM
tbird31's Avatar
Mine after porting, bigger valves and 5-angle valve job. There's probably a lot left in them, but for what I paid I'm more then satisfied.
Old 10-05-2010, 03:28 PM
RamAir95TA's Avatar
The best of the best, right here...
Old 10-05-2010, 04:30 PM
whytryz28's Avatar
Thanks guys
Old 10-05-2010, 04:31 PM
tbird31's Avatar
^^ who did yours? Why didn't you go back in and hand blend? Just curious.
joelster's Avatar
No love for AFR stuff????? lol, they make a nice product. These are a "race" ported set. The CNC'ing is a step above the 'street" ported versions. The "comp" ported ones are even finer in detail than these pictures.
Old 10-05-2010, 04:34 PM
whytryz28's Avatar
Im noticing a hole at the top of some intake walls, is that normal to leave open? Looks like a rocker stud goes there
Old 10-05-2010, 04:43 PM
RamAir95TA's Avatar
Yes, those holes are for rocker suds, and it is perfectly normal. There are also holes for IAC air.
Hand blend CNC heads? What's the point? The finish is already ideal. They are AI 200cc ported stock castings.
Old 10-05-2010, 04:49 PM
whytryz28's Avatar
Good stuff, just checking. So every other hole I make besides those would be bad right lol
Old 10-05-2010, 04:57 PM
joelster's Avatar
Here's a problem with running stock heads that are ported. You don't know exactly how much material you can remove and still be safe. I just took this pic from a pic that one of the guys above me posted. Notice the highlighted red area:
It looks like the porter "gasket matched" the initial opening but didn't blend it far enough in. I'm sure that flow would suffer when it gets choked down quite a bit from the large initial opening to much smaller csa about a 1/2" in. If you scroll up and look at the picture you will see that the other port doesn't have this obstruction. Maybe it's just the angle that the pic is taken from, who knows.
Old 10-05-2010, 07:21 PM
whytryz28's Avatar
^^^ I see what you mean joelster, thanks for pointing that out. Thats the area Im most concerned about.
Old 10-05-2010, 07:29 PM
Puck's Avatar
Max ported AFR 220s.
Exhaust Ports:
Intake Side:
Intake Ports:
Old 10-05-2010, 07:37 PM
speed_demon24's Avatar
Fixed
Old 10-05-2010, 07:42 PM
fex77k's Avatar
Who smoothed out the intake runners so much?
Old 10-05-2010, 07:48 PM
Puck's Avatar
Fixed the links, posting from cell and they didn't copy/paste the right ones.
Those are right after being milled so they have a little residue on them. They are not mirror polished, but very slightly textured, almost like leather.
Intake runner finish on EFI is not nearly as important as an old carb setup since modern fuel injectors do a much better job atomizing fuel.
Craig did them a while back BTW.
Old 10-05-2010, 08:40 PM
RamAir95TA's Avatar
Yes...hahah. If you do poke into a rocker stud hole, that's okay. Just make sure you put some thread sealant on that particular stud when it goes back in.
Old 10-05-2010, 08:45 PM
They look sandblasted to me.
Old 10-05-2010, 09:01 PM
Z8'S's Avatar
PolyDyn Thermal coating.
Old 10-05-2010, 09:32 PM
whytryz28's Avatar
Also at the back are the steam tubes or whatever, how do you guys get those bolts off, I couldnt and start to round one off, thinking about cutting in half and re doing it another way.
Quick Reply: Anyone have ported head pics they would like to share?
