runnin rich both banks
Old 10-06-2010, 11:02 AM
will02's Avatar
Default runnin rich both banks
codes p0172 p0175 pcm says runnin rich, worst case scenario is have to change fuel pump anyone had this problem? plz help dont have the cash for a new fuel pump right now.
Old 10-06-2010, 11:11 AM
69LT1Bird's Avatar
How do you figure that?
Did you look at the diagnostics for the codes?
Go Here:
p0172 p0175
Old 10-06-2010, 11:24 AM
will02's Avatar
yes used scanner
Old 10-06-2010, 11:26 AM
will02's Avatar
2 many diag steps just looking for a short cut or if anyone has come across this before.fuel pressure regulator intank with f/pump dont know if they sell it seperate thats what i mean by buying f/pump. diag steps says will be bad regulator
Old 10-06-2010, 11:46 AM
69LT1Bird's Avatar
Scanners tell you the code only. Follow the steps or take it to someone who knows how to work on cars, pretty simple. No place in the diagnostics does it say to replace the fuel pump.
Old 10-06-2010, 01:42 PM
2xLS1's Avatar
Why don't you tell us a little less about the car? If you thing the regulator is bad have you thought about maybe checking the fuel pressure on the rail with a fuel pressure gauge or are you waiting for someone here to tell you what your fuel pressure is. That would seem to make more sense than just throwing parts at it without a little diagnosis.
Old 10-06-2010, 02:17 PM
will02's Avatar
fuel press is borderline 50-52 psi, alldata end result for diagnosis says to replace fuelpump, regulator is built into it.
Old 10-06-2010, 09:53 PM
2xLS1's Avatar
Low fuel pressure would not set rich codes 0172 and 0175. It would cause lean codes 0171 and 0174 to set if low enough.
Old 10-07-2010, 12:30 PM
will02's Avatar
codes are p0172 p0175 for rich, low fuel pressure was keyon engine off.seems crazy low pressure but with rich codes!! checked pressure again is at 55psi.
Old 10-14-2010, 06:31 PM
will02's Avatar
no help in here!!
Old 10-14-2010, 07:33 PM
69LT1Bird's Avatar
The regulator is built into the sending unit that the fuel pump goes on, it is not built into the pump.
Old 10-18-2010, 09:50 AM
will02's Avatar
fuelpump and regulator sold as 1 piece, wholeunit!!
Old 10-18-2010, 10:16 AM
ElecTech's Avatar
If your fuel pressure is holding in the 50's, then nothing in the tank is the issue. Time to look elsewhere.
If you don't care to share what has been done (if anything) to your car, you'll get very few suggestions.
Old 10-18-2010, 03:22 PM
will02's Avatar
allstock only catback exhaust and throttlebody spacer... possible leaking injectors?
Old 10-19-2010, 06:55 AM
ElecTech's Avatar
Does the fuel pressure hold in the rails with the key off?
Old 10-22-2010, 04:06 AM
2001WS6Vert's Avatar
Try cleaning the mass air flow sensor.
Old 10-22-2010, 06:39 AM
CalEditor's Avatar
The fuel pressure would have to be really high. You are at least 40% extra fuel
The Purge valve can cause this if it is stuck open, but you should set a DTC for purge when no purge commanded
The MAF could be the cause, but the MAF sensor would have to show 40% extra airflow. That is hard too do. Usually the show less airflow when they are bad
The IAT sensor can cause this issue. I have seen it a few times. The IAT sensor will read lower temp than it is. Either a bad sensor or the wires break at the sensor. Before the wire break off the high resistance in the circuit causes the reading to be incorrect, but not -40° so no DTC is set. Then the car comes in later with the IAT sensor DTC set
The ECT can cause this DTC also. The scan tool will display the ECT at a low number like 70° when the engine is up to temp.
Remember you are over 40% rich to set the DTC.
Old 10-22-2010, 11:50 AM
will02's Avatar
sorry havent replied been busy @ work! tried injector balance test with scan tool says there is a injector balance problem havent figured that out yet! any ideas?
Quick Reply: runnin rich both banks
