Hand ported 241 heads (pictures)
Old 10-06-2010, 07:29 PM
camz28arro's Avatar
Default Hand ported 241 heads (pictures)
Just finished porting my 241 heads using a dremel, it took 30 hours total to do both heads.
I got rid of the rocker bolt hump, smoothed the runners with 80 grit sand paper rolls but removed hardly any material, narrowed the valve bosses but didn't go crazy, removed 25% of the intake ramp but still wanted it to do it's job and blended/matched everything. I would guess the runners are still only about 210-215cc/75cc. and the heads should flow around 270-275cfm, better than stock Ls6 heads (260cfm)
These heads are also be in the for sale section since I only ported them to sell them. Came off my 2002 camaro with about 45k miles. Only $500 with valves and stock springs. My camera sucks at taking close ups so they look a lot better in person.
Attached Thumbnails Hand ported 241 heads (pictures)-img_2688.jpg   Hand ported 241 heads (pictures)-img_2689.jpg   Hand ported 241 heads (pictures)-img_2663.jpg   Hand ported 241 heads (pictures)-img_2669.jpg
Old 10-06-2010, 07:43 PM
02 BLK WS6's Avatar
Nice. I did a set of 241's not nearly as well as you did these and noticed a decent gain. My car is full weight and ran 11.80 @ 114.7 last night. Previous best n/a was a 12.12 @ 112 with the stock 853 casting heads.
Old 10-06-2010, 08:08 PM
garygnu's Avatar
did you do a valve job?good work.
Old 10-06-2010, 08:13 PM
camz28arro's Avatar
Heads still have the stock valve job but I stayed away from the valve seals with the sander/grinder.
Old 10-07-2010, 11:56 AM
Mart00SS's Avatar
Ehhhh, not tooooo bad but not too great either. You could have taken a little more out of the rocker boss and tryed to smooth the valve stem guide a bit better. Maybe even do a bit of blending the seat to the bowl also. I'm sure using a dremmel was not easy, you really need something with more torque than a dremmel, such as a die grinder that runs off a compressor.
Old 10-07-2010, 04:17 PM
camz28arro's Avatar
I did slightly blend the seat to the bowl but not all the way since it takes forever with a dremel, Like I seid though the pictures don't do it justice. I took some more exhaust pictures to try and capture it better.
The camera is too sensitive to the light so it picks up the reflections where it looks like there are chips in the ramps.
Attached Thumbnails Hand ported 241 heads (pictures)-img_2707.jpg   Hand ported 241 heads (pictures)-img_2706.jpg   Hand ported 241 heads (pictures)-img_2705.jpg
Old 10-07-2010, 07:31 PM
camz28arro's Avatar
UPDATE: Well I went back over the heads like you said. I took more out of the rocker bolt hump, blended the seat with the bowl, and cleaned everything up. Don't forget my camera sucks for close-ups though..looks better in person.
Attached Thumbnails Hand ported 241 heads (pictures)-img_2709.jpg   Hand ported 241 heads (pictures)-img_2710.jpg
Old 10-07-2010, 08:12 PM
01cherryreds10's Avatar
You could go to your local auto parts store and get the lapping tool and lap the valves. We did it on my dad's Olds' heads and they turned out pretty nicely for $15 of materials.
Old 10-07-2010, 08:30 PM
camz28arro's Avatar
I might lap the valves but would rather just sell them as is and stop dumping money into them, already up to $200 on the dremel, carbide bits, sanding rolls, ect
Old 10-07-2010, 08:37 PM
LS-240's Avatar
there needs to be a thread where these terms are explained and arrows are drawn to the areas that they apply to, just an idea. but i'm sure you pick up the terms after some research and reading. is there a self porting thread?
Old 10-07-2010, 08:46 PM
camz28arro's Avatar
There are a few porting threads, try searching "DIY porting" or "Hand porting" Spend a lot of hours going through them before I tackled these heads.
Old 10-07-2010, 08:55 PM
garygnu's Avatar
hard core has some pics of DIY porting,or talk to nitroses383 about porting.
Old 10-07-2010, 09:47 PM
Mart00SS's Avatar
Heres my thread
Got good pics and flow numbers.
https://ls1tech.com/forums/generatio...d-porting.html
Quick Reply: Hand ported 241 heads (pictures)
