Cadillac L92 throttle body
Old 10-07-2010, 08:52 AM
GTO 3447's Avatar
Default Cadillac L92 throttle body
How big is the throttle body on a 2009 L92 out of a 2009 Escalade? I read somewhere it might be 87mm.
Would the smaller size hurt performance?
If it is 87mm how big can I have it bored out?
Old 10-07-2010, 04:34 PM
Taspeed's Avatar
smaller size won't so much hurt performance as it will hinder it I believe most TBs can be ported and net an extra 3 or 4mm.
Old 10-07-2010, 04:57 PM
Jon@Texas-Speed's Avatar
I wouldn't mess with trying to enlarge the opening. Porting them usually involves smooting out the inlet but doesn't make it bigger. If you start opening it up you will more than likely have an issue trying to make it seal again. I would leave it smaller if it actually is and just use it rather than opening it up.
Jon
Old 10-07-2010, 11:43 PM
GTO 3447's Avatar
I have to do some research to find out the size if it is smaller. If it is an 87 WHAT GAINS cannot be realized by going to a stick 90 or aftermarket 92 or 102 throttle body?
Old 10-08-2010, 07:06 AM
Unertl42's Avatar
not enough difference to justify the $
Quick Reply: Cadillac L92 throttle body
