What Wideband O2 for EFI Live v2?
Old 10-07-2010, 10:10 AM
blsnelling's Avatar
Default What Wideband O2 for EFI Live v2?
I'm ready to dial in my WOT AFRs, so am looking for a wideband O2. Seems like the LC1 is highly recommended. Is PN 3769 all I need to connect with my EFI Live v2? Or is there a better option out there?
Old 10-07-2010, 05:25 PM
BLK02WS6's Avatar
Personally, I like the LM-2... and whichever you decide on, I would use a serial cable vice the analog - much better signal and no grounds to worry about causing the readings to be off... here is where to get them:
http://www.taquickness.com/taqcables.htm
Old 10-08-2010, 02:39 PM
shoemike's Avatar
Definitely take advantage of the serial connection the V2 has.
Anything with serial output and the ability to calibrate the sensor.
Supported Serial WBO2 Controllers for EFILive V2
Quick Reply: What Wideband O2 for EFI Live v2?
