McLeod Master Cylinder Rebuild Kit
Ok, I have a McLeod MC that I bought in October 2008 (so it should be the 2nd generation, right?). I've been having a sticking clutch pedal, so I pulled the MC apart and found a small chunk missing from the cup seal (towards bottom of pic, hard to see):
So I need a rebuild kit. I see that Thunder Racing sells this one:
http://www.thunderracing.com/shop-by...inder_295.html
Are the LS1 and LT1 McLeod MC's the same? On my Summit invoice, it says I ordered MCL-139001 (that's the MC), so I assume so. Will this rebuild kit work for me then? This is my DD, so I want to get her running good again. Thanks for any help!
I just thought I would update this in case anyone needed the info.
The rebuild kit I asked about turned out to be for the 1st gen MC. I contacted McLeod and they sent me the correct one, free of charge.
So I rebuilt it myself, and the MC works just like new again.
Everything is on this thread in the Manual Transmission section:
https://ls1tech.com/forums/manual-tr...build-kit.html
