Another Ticking with high oil pressure, bit different then others
Hello and thank you for reading,
First let me say I have spent a lot of time researching this issue and am a bit lost, watched countless vids and read a lot of threads but there are a few things that seem different in regards to my engine that give me the impression that it’s nothing I read about yet...
Second the most recent things I have done is changed my oil about 2 weeks ago and my plugs 3 weeks ago.
Third no major mods on the car except headers, exhaust, made my own little intake.
Fourth, 127K miles, I drive conservatively in general, but this started the day after I went WOT for about 8 seconds or so playing with a 350Z.
Fifth, I double checked all the plugs and added the Lucus oil additive with no luck.
Now to symptoms, Cold start it’s nice and quiet with no tick, oil reads 60-70psi, warms up and ticking starts, oil pressure going to 20-30psi. Ticking becomes noticeable at 2k RPM, gets worse about 3K and dissipates as the RPM’s get higher. I would think its rockers, springs, lifters or O-ring, don’t think its rollers as the pressure would be lower, don’t think its plugs as they seem good. I will attach a vid here in a few.
Any input would be nice before I start pulling heads and such... Thanks for your time.
uploaded vid:
http://www.youtube.com/watch?v=tMeynXgPCoQ
uploaded vid:
Hmm, this happened within 1-2 days? The on set seemed so fast I would think that its not the bearings. And what kind of rebuild kit would you recommend? Thanks for your input though. Vids loaded now if you want to hear it first hand.. It does get a bit louder then shown but its basically the same sound.
I thought it sounded like a lifter also and it seemed to be on the pass side in the back it could be one of the rockers loosing the needle bearings .. I WOULD PULL THE COVER AND CHECK AND SEE IF ANY THING IS LOOSE NOT THE BOLTS BUT THE ROCKER/PUSH RODS
hmm, I suppose I'll give that a shot tomorrow, thanks for the insight, if anyone else has an opinion I would love to hear it. keep em comming heh
Pull the oil filter and cut it open, If its a bearing you will see something in the filter. If its clean could be a cracked spring or bad lifter. I'd start checking some things before any bg damage happens.
do springs loses enough presure to cause this,or do the O-ring break down and bleed oil pressure?pull the valve covers and inspect closely with a brite lite,and check the oil drain plug for needle bearing.
Thanks for everyones input, I will be breaking it down starting with the heads and going down the block here shortly... I built a eclipse quite some time ago, JE pistons and eagle rods, that was a lot for a 4 banger.. This scares me a bit.. Cams, lifters rockers stuff like that is a reasonable amount of labor.. but the bottom end, jesus.. I wanted this to be a drag car but I dont even have a rear end yet. I'm at a loss as to how to go about this atm. Well thanks for the insight, as I pull this apart I will take pictures and let everyone know.. Maybe people can learn from the vid and know yet another thing that falls apart in this car with little to no cause..
And by all means if anyone else has any idea's feel free to let me know, the more options the better always.
Thanks,
Ian
Thanks,
Ian
Trunion King
Yeah, don't take it all apart yet. Start w/ taking the valve covers off and check for loose or big amount of play on rocker arms, springs, pushrods.
Before all of that gather all of your needed parts ie: head bolts/gaskets, O ring/new oil pump, timing chain, water pump gaskets, fluids... if you have needle bearing problem, you will need to get a new trunion rocker arm upgrade from comp cam.
Follow LS1howto.com on disassemble/assemble the motor. Don't follow the rocker arm installation though, use the GM procedure.
