New LS1 Owners - Newbie Tech - 5.3 engine interchange?
Gus_Mahn
10-09-2010, 05:13 PM
My brother needs a engine for his '99 5.3 Z-71. The truck is nice, so he wants a low mileage used engine. I believe the direct interchange is '99-'04. I've also heard that '05 and up can be used but requires some changes mostly with regards to the number of teeth on the crank trigger. I was told there's an electronic box to do this. Can anyone shed some light on this project? Thank You!
1BAD_LS1
10-09-2010, 07:28 PM
you are correct! direct swap!
Gus_Mahn
10-10-2010, 08:09 AM
you are correct! direct swap!'99-'04? What about '05 up in a '99 truck? I've found an all Al 5.3 out of an '07 TrailBlazer with 1000ish miles. What will it take to get it in the '99?
kinglt-1
10-10-2010, 10:13 AM
i think you need a 58x conversion but I may be wrong... Contact efi connection.
SOMbitch
10-10-2010, 10:15 AM
Lingenfelter sells a box that will convert the crank trigger signal so the older pcm can read it.
Gus_Mahn
10-10-2010, 11:52 AM
That damn box is $250! I assume there is no budget way to do this? If not, I'll just stick to '99-'04 engines.
PitchblackC3
10-10-2010, 12:08 PM
All the engines in the GMT800 trucks are 24x trigger. That means 99-06 and 07 classic.
The other variants like trailblazer may have switched earlier.
Gus_Mahn
10-10-2010, 12:45 PM
The other variants like trailblazer may have switched earlier. That's a black crank senor right? I read the grey ones are 58x. Were is the sensor located?
PitchblackC3
10-12-2010, 09:31 PM
The crank sensor is above the starter on the truck engines. I think it is in the front cover on the LS2.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
