Timing cover gasket or RTV?
Old 10-10-2010, 01:34 AM
some_punk's Avatar
Default Timing cover gasket or RTV?
I am in the process of a doing a heads and cam swap. I was wondering can I use high temp RTV on the timing cover instead of the timing cover gasket? And Everyone on here seems to say just put a dab of RTV, but on Ls1howto.com says to put a bead along the bottom of the timing cover. Which way is better?
Old 10-10-2010, 01:38 AM
Arc00TA's Avatar
Use the gasket. If you have ripped out any of the rings around the bolts you will need a new one, as it will definitely leak. If you take that gasket spacing out of there your front crank seal may not work properly.
You only NEED to put a line of RTV on the corners, right where the block and pan intersect.
Old 10-10-2010, 03:08 AM
BennyB's Avatar
yep just a coulple dabs at the bottom corners of the front cover
Old 10-10-2010, 07:55 AM
vettenuts's Avatar
The key thing is to center the cover on the crank, and measuring with a 6" metal rule works better then using the pulley. There is no guarantee it is centered using LS1howto's method.
Old 10-10-2010, 10:52 AM
LSX Mechanic
Damian's Avatar
Most definitely not RTV. You're not working on an iron small block chevy. These motors do not go together like those. Use the aluminum/rubber gasket.
Old 10-11-2010, 01:54 PM
some_punk's Avatar
does anyone have a picture of the locations of the spots to put the RTV stuff?
Old 10-11-2010, 02:00 PM
blsnelling's Avatar
Just the two bottom corners, where the front cover, oil pan, and block all intersect.
Old 10-13-2010, 09:00 PM
some_punk's Avatar
should there be any on the bottom of the timing cover gasket too? and will the ls1howto method of centering the timing cover be good enough?
Old 10-14-2010, 01:53 AM
caseypryan's Avatar
this ^
Old 10-14-2010, 10:18 PM
some_punk's Avatar
Originally Posted by caseypryan
this ^
What i am trying to ask is should there be any at the bottom between the timing cover gasket and the block and the pan.
Old 10-15-2010, 07:35 AM
Gonoma's Avatar
he already answered that for you
Old 10-15-2010, 10:36 AM
ND400's Avatar
Lay of the crack. I'd come there and sucker punch you myself. If you used RTV
Old 10-15-2010, 11:02 AM
blsnelling's Avatar
What else can we tell you?
Old 10-15-2010, 11:09 AM
Jim_PA's Avatar
Don't clean off the front of the block, the dirt marks made from the timing cover will allow you to re-install it without worrying about it being off-center
Quick Reply: Timing cover gasket or RTV?
