Torque converters
Old 10-10-2010, 08:19 PM
rufrntn's Avatar
Default Torque converters
I got a 95 z28 I need a new torque converter. I finally decided I am getting a 3000 stall I have about 500 maybe 600 which brand or options should I go with. I'm very ignorant with these thanks for any help
Old 10-10-2010, 08:58 PM
96capricemgr's Avatar
I am very happy with Edge Racing Converters, they are cheaper than some of the others because they do not have the expensive billet cover which is why they are only about $525 as opposed to $700+ for some other brands. A street/strip NA LT1 doesn't need a billet cover though so it is a safe way to save some money.
If they can make my over two ton barge cut 1.53s NA they have to be doing something right.
Old 10-10-2010, 09:20 PM
TheTransporter69's Avatar
make sure you get a tranny cooler as well when installing a converter.
Old 10-10-2010, 11:21 PM
LSWHO's Avatar
I had a fuddle 3k that felt REALLY good when you got on it. It must have had some crazy STR (it had to be higher than they told me it was), and lower topend power, but it felt AMAZING when I got on it for how little power I had.
I never got it to the track because my stock tranny crapped the bed.
I then got a performabuilt 3200 which has treated me well but they are pricey.
One thing I'd suggest... don't go below 3600 even on a stock car. I'd never go this low again.
If I did it all over I'd have gotten a yank ss3600 or vig3600 right away.
Old 10-10-2010, 11:27 PM
marc97taws6's Avatar
What are your goals for the car in general?
And I'd personally wait and shell out some more coin on a converter or go with an Edge like Caprice said. Converter isn't something you skimp on
Old 10-10-2010, 11:30 PM
gregrob's Avatar
Not gonna do better than ATI but you will pay for it
Old 10-10-2010, 11:52 PM
rufrntn's Avatar
Got the Hayden 1405 trans cooler. My power goals for the car are about 375-400 at the crank.
Old 10-11-2010, 05:31 PM
Which ATI would you recommend??? Have a PN for a small diameter high stall 4L60E lockup unit?
Old 10-11-2010, 06:04 PM
gregrob's Avatar
No I dont. I'm an M6 car, I have friends who run them all and I like the way the ATI's perform the best.
Talk to Ed Wright, I believe Abare, and a LOT of other fast guys who have tried most of the converters out there, and stick with ATI.
Besides I wouldn't be giving someone a "part number" I would have them call ATI and have them put together something application specific...
Old 10-11-2010, 06:23 PM
Those cars you are talking about use 8" Treemaster non-lockup converters not really something appropriate for a street car. Believe about 4200 is as low a stall as you can get those in.
ATI absolutely makes a good product but I don't think they have a 9.5-10" lockup high stall 4L60E unit. Which is what the OP should be looking for.
Old 10-11-2010, 06:28 PM
kinglt-1's Avatar
check out FTI converters...
Old 10-11-2010, 06:29 PM
gregrob's Avatar
Even the street converters I've seen work well, but so do Circle D, Yank, etc.
Old 10-11-2010, 06:50 PM
355z28's Avatar
yes, yes they do Im happy with mine. I just need to stick a good tire and some drag shocks and hopefully ill be able to take advantage of it a bit more.
I've had some expierence with edge converters as well, they are very street friendly and feel like stock.
Old 10-11-2010, 08:08 PM
rufrntn's Avatar
I just ordered a 2800 stall edge converter from probuilt. What else will I need? Probably some kind of tune?
Old 10-11-2010, 08:38 PM
gregrob's Avatar
Should have went bigger. Is it a lockup? If so there's no reason not to go 3400+. A quality converter drives great on the street.
Old 10-11-2010, 09:31 PM
Wicked94Z's Avatar
yea.... with lock-up there's no reason to be that conservative on the converter. Edge does make a good converter, they're a local shop. A lot of quick cars down in san diego are running their stuff. not 4L60Es though.
Old 10-11-2010, 10:03 PM
IronOutlaw's Avatar
I'm gonna go against the grain and say 2800 is fine for a street car. I ran a 3600 yank and couldn't hook for shut on street tires. With my 2500-2800 stall I have now I can take off alot harder without spinning. 3600 is good but you'll need suspension and tires to make it worth while IMO.
Old 10-11-2010, 10:09 PM
rufrntn's Avatar
It's gonna be my daily driver. Well only durring road construction season. I don't want to go too much so maybe 3200??
Old 10-11-2010, 10:20 PM
whytryz28's Avatar
Im running a Yank SS3000, 3 transmissions later and its still holding up fine.
Old 10-11-2010, 11:04 PM
gregrob's Avatar
3400 minimum. You'll thank me later.
Quick Reply: Torque converters
