need some tips and tricks!
Old 10-10-2010, 10:17 PM
LS6 Z28's Avatar
Default need some tips and tricks!
Hey everyone I got a quick question about the LS1 throttle body. As of recently i've been getting the itch to port my tb myself so tonight i started to. About 10 minutes ago i was able to get all the bolts out, disconect the battery and all the other electronic intake plug ins. Where im having trouble are in these damn rubber tubes or piping i guess you would call it. My question is, is there any easy way to get these off because the clamps on mine are all rusted to **** and i've tried getting a small flat head under the rubber but after prying on them it looked like it was going to crack. Any suggestions? Ive been trying everything I can think of and no luck so far.Ill post up pics shortly.
Old 10-10-2010, 10:31 PM
LS6 Z28's Avatar
Well for some reason my computer wont allow me to upload the pictures so ill just be more descriptive. The only 3 rubber tubes connected to the throttle body. They are ALL stuck and i can't get them off. Is there any easy way to do this?
Old 10-10-2010, 10:55 PM
99huggerorangeZ's Avatar
use a hose pick and go around the whole inside lip of the hose and then pull off.
Old 10-10-2010, 11:23 PM
LS6 Z28's Avatar
Well unfortunately I don't have a hose pick but do you think if i keep spraying them with WD40 and keep prying on them with an extremly small flat head ill be able to get them off? I've never seen rubber hoses so tight.lol its frustrating it ended up turning a 10 minute thing tops into a long sprawled out process.
Old 10-10-2010, 11:39 PM
or you can use a set of adjustable pliers/channel locks but wrap a rag around the hose so you dont damage it and give it a twist. it should break the seal and allow you to pull it off.
Old 10-10-2010, 11:57 PM
LS6 Z28's Avatar
Ok ill try that and hopefully this time around they break loose. Thanks for the input 99huggerorangeZ
Old 10-11-2010, 12:44 AM
NP,let me know if you need anymore advise.
Old 10-11-2010, 08:50 AM
thunderstruck507's Avatar
cut them and do a tb bypass when you put it back together
Old 10-11-2010, 09:21 AM
bayer-z28's Avatar
Don't hog out too much. Here is a diagram of what you are looking to remove.
Old 10-11-2010, 09:22 AM
bayer-z28's Avatar
I got that f Teke184's cardomain page. RIP buddy. Were still using your advice that you handed down.
