Exhaust problems after Poly Motor Mounts
Old 10-10-2010, 11:00 PM
Greenbird97's Avatar
Default Exhaust problems after Poly Motor Mounts
So I installed brand new urethane motor mounts in the stock clamshells when I changed out my motor recently. I have American Racing Headers and their offroad y-pipe. The exhaust used to have perfect clearance on the stock motor mounts, but now that I have the urethane ones, the exhaust sits several inches higher. Now the the y-pipe rests slightly against the floorboard in one spot, rests against the fuel lines in another spot, and barely rests against my drive shaft safety loop. Everyone always talks about how good y-pipe clearance is with poly motor mounts but mine is much worse now than before...what should I do? Install a bump stop like this: http://www.thunderracing.com/shop-by...anger_528.html
or have an exhaust shop weld up something? Any advice?
Old 10-11-2010, 07:04 AM
Hardtop's Avatar
I have the exact same setup with no problems. Did you try loosening the y-pipe and adjusting it for more clearance? Mine is hooked to a Magnaflow cat back, and nothing hits or rubs.
Old 10-11-2010, 07:32 AM
LS14EVR's Avatar
I have exact same set up as well and no issues. I'd loosen Y pipe and headers, then adjust and retighten.
Old 10-11-2010, 09:27 AM
I'm kind of confused how can you move the exhaust down several inches by just loosening the clamps?
Old 10-11-2010, 10:04 AM
Joshiedoom's Avatar
My headers got worse clearance with poly mounts as well, like you said it brought it up wayyy to much.
Old 10-11-2010, 10:10 AM
So did you switch back to stock ones or did you find a way to fix your clearence issues?
Old 10-11-2010, 10:14 AM
Joshiedoom's Avatar
I switched to TSP Duals and it clears the floorboard better but I plan on changing the entire k-member. The headers still almost rest on the k member and when the engine is under load at low rpm it occasionally taps it. Its annoying as hell and its only on the drivers side ironically.
Old 10-11-2010, 10:15 AM
StangeatinZ28's Avatar
heat the y-pipe up in the area it's hitting and bend it down. kind of a shitty way of doing things but it works :shrug: no use in changing your entire exhaust system because of some clearance issues
Old 10-11-2010, 10:24 AM
Ya by no means do I have the funds right now to replace the entire exhaust
Old 10-11-2010, 10:28 AM
Joshiedoom's Avatar
The y-pipe isnt the issue unfortunately Ill get some pics in a second. You can call my local exhaust shop and they heated my ypipe at the collectors and at the y to recorrect the angle. Which ironically fused my headers to the ypipe and I had to cut the SOB off in a few places.
Old 10-11-2010, 10:33 AM
Element's Avatar
You can also get some exhaust/header wrap and wrap the area that's hitting...it'll deaden the sound a bit.
