Water pump coupler
Water pump coupler
I was replacing the water pump on my 96 ws6 and accidentally lost the coupler that connects the driven gear to the water pump. Does anyone know if this only goes on one way? The reason I ask is that on end has a groove near the end of the shaft. I just need to know which way this is supposed to be installed.
http://shbox.com/ci/water_pump.jpg
If you changed the seal, it is very easy to mess up and you might need to redo it.
http://www.impalasuperstore.com/nais...TOPIC_ID=30984
