Pedal not responding "p2138"
Old 10-11-2010, 07:57 PM
AmPleZeMi4's Avatar
Default Pedal not responding "p2138"
I have a Ls2 out of an 07 corvette, I am using an 07 cts-v ecm (e67) with cts-v base tune, and a 06 SSR pedal. The issue I am experiencing is the pedal is none response, when I turn the key in the on postion the TB moves and makes noise, however with the car running the is no communication between the TB and the pedal. I show one error code p2138. HELP PLEASE!
Old 10-11-2010, 08:07 PM
AmPleZeMi4's Avatar
I've been told i need a 07 ctsv computer or trailblazer ss 07-08 tune
Old 10-13-2010, 02:10 AM
69cutlassrkt's Avatar
Is your TAC Module the right one for your PCM you are using?
I know spear tech can tell you which tac module you need if you ginve them the numbers on the PCM
Quick Reply: Pedal not responding "p2138"
