Oil leak
Oil leak
My motor was just rebuilt used all felpro gaskets and i have a leak to the oil pan in the front its like 4 or 5 drops in a damn line i used synthetic this time could that be the issue i thought it would go away but 300 miles later its still there any possible suggestions upon it
You are not supposed to break in a new engine with synthetic oil. Drain it out and use conventional.
The front timing cover seal is a very common oil leak location. Did you install the Felpro oil pan gasket dry or with RTV? Are you sure it isn't the front main seal?
[QUOTE=RamAir95TA;13979607]You are not supposed to break in a new engine with synthetic oil. Drain it out and use conventional.
X2
and synthetic isn't " dat or ****" your just not using it properly... use it after breaking in motor... and sounds like one or many of your seals weren't installed properly
X2
Village Troll
Too many variables to say it's the oil pan gasket unless you have zeroed in the source. Simplest way to go about it is to start feeling around your timing cover and see if you feel oil up past the oil pan. Do you see any oil that has been slung? Usually that will mean oil is getting past either/or/both the water pump drive shaft and the opti drive.
As stated, if the water pump seal is not put on correctly it will leak like a sieve. There are how to threads you can search for that will tell you how to properly install the seal. If you find out that is the case then buy a few of them. The first one may not go on correctly and you don't want to be stuck on a weekend when the dealer is either closed or has to order one...
