Gears & Axles - Explain a Spool to me
3.8redbird
10-12-2010, 12:00 AM
I hear alot about spools and other systems for a solid axle.
What are the differences and pros/cons to each?
I looked in the sticky and I think this thread could be a good one to add to the links list.
Thanks
01ssreda4
10-12-2010, 03:53 AM
A spool is straight up hooking the left and right tires together with a solid piece of metal. No give at all. Shit will chew yours tires up driving around sharp corners doing street driving. But they are super cheap.
Bob@BruteSpeed
10-12-2010, 05:14 AM
https://www.brutespeed.com/rear_end_information.htm
I have info on the spool at the above link. Bob
BlackScreaminMachine
10-12-2010, 07:37 AM
Good Link Bob.
Tire wear definitly increases but on top of that the tire scallops and often you need to burn that shiz off to get a clean surface.
One thing that I thought was amusing was pushing JL-ws6's car from the garage, to his trailer but the car needed to be turned to the left and straightend out to the right. The car had a gutted body, no motor, no trans, just a 12 bolt w/ spool and bias plys as well as skinnies and manual rack. That car was VERY hard to push and turn at the same time. Kinda embarrasing.
3.8redbird
10-12-2010, 09:30 AM
What are the other options?
SO a spool is just like what the jeeps and whatnot do to get the tires both spinning when they only have a one-wheel peeler?
3.8redbird
10-12-2010, 09:41 AM
Thanks Bob. your whole site is sticky material
greencactus3
10-12-2010, 11:27 AM
there are a range of options between spool and open diff.
varying versions of lockers and limited slips.
torsen, viscous, salisbury etc
dutinsss
10-12-2010, 01:11 PM
yea. spools far from the only way to get both your tires to spin. spools are just cheap, simple, and strong compared to the rest, but as said, will take away from the smooth operation of a limited slip unit.
3.8redbird
10-12-2010, 01:40 PM
I just have seen the term spool tossed around locally and on here so wanted some clarification. The detroit or wave on Brutes website seem the best bet for a street car.
Egg1456
10-13-2010, 12:36 PM
U could get a locker soo its open when you want and a spool when you dont. http://www.youtube.com/user/SummitRacingVideos#p/u/0/AiuH-FeC-Ho they have alot of technical views of different diffs on there
10-13-2010, 01:25 PM
On a M6 you do NOT want a Locker. :judge:
3.8redbird
10-13-2010, 01:59 PM
M6 is for roadracing. A2/A3/A4 is for the drag racing
93camaro_zzz
10-14-2010, 12:28 AM
Oh Naaaaaw he didn't!!!
3.8redbird
10-14-2010, 12:50 AM
And live long? lol
dimetweaker
10-14-2010, 01:39 AM
and why is that?
SS4Luck
10-14-2010, 03:44 AM
+1 for that! I have spent many late nights cruising and reading and learning new stuff.
dont forget you can go with a wavetrac!!!! :)
3.8redbird
10-14-2010, 07:19 AM
Thats what looks to be my best option for a street only setup with 1 pass before being booted from the track and never going back lol
10-14-2010, 08:13 AM
and why is that?
Do a search, plenty of info.
http://www.ls1tech.com/forums/gears-axles/1312104-review-locker-m6.html
Search here under "Locker M6"
dutinsss
10-14-2010, 04:20 PM
you can run a locker with an m6 just fine. it'll be harsher with an m6 but it's all personal opinion. unless you see a lot of track time, i'd stick with a limited-slip unit though. if you get a good one, your probably not going to hurt it on the street.
