ebay roller rockers ???
Old 10-12-2010, 10:00 AM
RNation0001's Avatar
Default ebay roller rockers ???
anyone know anything or use these roller rockers from ebay? im wanting to get a 1.8 set of rockers to use with my ls9 cam for my turbo engine and came across them
http://cgi.ebay.com/ebaymotors/CHEVY...item5adcc9764e
Old 10-12-2010, 10:14 AM
LS1Tech Sponsor
hellbents10's Avatar
Looks like a Chinese knock off of a Comp ProMag rocker. I would stay far away from them.
Old 10-12-2010, 11:22 AM
well they look halfway decent made i was just wondering if anyone had tried them
Old 10-12-2010, 11:27 AM
Mean87SS's Avatar
I wouldnt risk one...
Old 10-12-2010, 11:28 AM
Phantom's Avatar
junk...the ones i received from shannons engineering were used, they tried to deny this but the bushing, yes bushing, not bearing was clearly worn, the only reason I noticed this because the rocker was hard to rock. so we took it apart and found that. pretty much, you get what you pay for
Old 10-12-2010, 11:35 AM
Jim85IROC's Avatar
It's hard to make an extruded aluminum piece "look" bad... it's the metallurgy and the bearing quality that will kill your motor, not their appearance.
Old 10-12-2010, 11:38 AM
wbb
wbb's Avatar
my buddy has these on his fire hawk w/a 70mm tubonetics turbo no problems as of yet but to each his own.......
Old 10-12-2010, 11:41 AM
sidewayz28's Avatar
you should give it a shot..
Old 10-12-2010, 11:48 AM
NemeSS's Avatar
ive seen em, they look good, cheep and tempting. but i dont know if its worth risking my motor if they fail.
however i would consider using them in a junkyard motor and beat on them. if the motor goes. no biggie
Old 10-12-2010, 12:26 PM
true i may try them on my stock 5.3 im puttin in my chevelle but prolly not this one i guess. thanks for the input
Old 10-12-2010, 12:33 PM
LilJayV10's Avatar
If you decide on a set of 1.7's rollers let me know.
Old 10-12-2010, 12:46 PM
if i get aftermarket ones they will be 1.8 just because the stock 1.7's are very good roller rockers already i just want my lift from this ls9 cam to be right at .600" lift
Quick Reply: ebay roller rockers ???
