Cam position sensor keeps going bad?
Old 10-12-2010, 06:44 PM
Sideways240sx's Avatar
Default Cam position sensor keeps going bad?
Ok. put together a new motor.. Used my old harness. I dont remember pins off top of my head, but i have the 12v, ground, and signal wire. All wires work, no pinch's and no burns. They all ohm out between ecu side and sensor side.
So I started with a brand new sensor. Worked fine, never saw a code. Went to dyno, after the first pull i was getting a code and it was not reading. tuner had some used ones laying around. Put one in, and it worked. Finished tuning, Went to the track ran the car was fine for several runs. End of the night, cel comes on, and it says cam position sensor again. I reset it and it stayed off for a little while. What could be causeing this? i tried to search, didn't see anything.
Thanks in advance, Chris
Old 10-12-2010, 09:18 PM
RPOWU8's Avatar
I had similar problems though I did not replace the cam sensor. I reset the CEL a couple of times. Cam gear bolts had come loose and the cam gear was moving around. Cam walked back and took out the lifters and the entire shortblock.
BEWARE: the cam bolts torque specs from GM are wrong. If you torque the cam bolts down to 18 ft lbs per the GM spec you're cam gear will come loose.
I even used red loctite.
Not to scare you but I would check and see if the cam gear is loose. Do not drive it until you check it. I took out a LS3 Crate motor in less than 500 miles.
My .02.
DJ
Old 10-12-2010, 09:21 PM
My .02.
DJ
Fml. The people that did the motor installed the cam, and cam gears, and chain ect....
You just scared the crap out of me.
Thank you though, Chris
Old 10-12-2010, 09:26 PM
Formerly 99-2door-08/30/2010
PitchblackC3's Avatar
Yikes, let us know how this turns out.
Old 10-12-2010, 09:38 PM
I hope/ dont think this is the problem. but now i have to check it. I was going to pull the trans and send the converter in to get it restalled, its a little to loose, so i guess i can pull the turbo,crank pulley, and front cover.
Thanks, Chris
Old 10-12-2010, 11:18 PM
RPOWU8's Avatar
Re-read your post: This would apply to a LS2 or LS3 with cam sensor in the front cover. If its a LS1 sensor, you should be OK.
I guess I have LS3 on the brain.
DJ
Old 10-13-2010, 04:21 AM
Ok, Thank you.
Chris
DJ
Old 10-13-2010, 06:17 PM
Broke EF's Avatar
BUMP!!! We need answers here people!
Sean
Old 10-13-2010, 10:43 PM
Mike454SS's Avatar
Are the dead sensors coming out looking like they've made contact with anything?
Old 10-14-2010, 05:21 AM
Nope. They look perfect!
Thanks chris
Old 10-14-2010, 06:37 AM
C5kid's Avatar
It still could be a loose cam.
My buddy in his 04 vette randomly had a cam position sensor code. I did some research on corvetteforum and turns out it was loose cam bolts. This was a bone stock car, just CAI and TB swap.
When we got the cover off you could see there was about 1/16" gap between the heads of the bolts and the cam sprocket. He was CRAZY lucky they didn't back out any further and trash the motor.
One sign that he noticed before the code started was the car seemed to crank longer than normal. He tought maybe his battery was goin bad, until the cam sensor code popped up.
Old 10-14-2010, 12:08 PM
Sounds good. I will definatly check it before i run the car again. Sometimes my car is a little tuff to start.
Thanks for ur post.
Chris
Old 10-14-2010, 03:23 PM
joecar's Avatar
You may need to find someone with an oscilloscope (who knows how to use it) to look at the CMP waveform, this will give a clue as to what is happening (cam walking vs intermittent wiring).
Old 10-14-2010, 04:37 PM
Broke EF's Avatar
That is something we do have acess to. If we pull the cover off and that all looks fine then I guess we can go down the route.
Sean
Old 10-14-2010, 06:45 PM
I will check the cam in the next two weeks. This weekend is already shot! Thanks everyone for there help. if anyon else has any ideas, please let me know.
Thanks, Chris
Old 02-15-2011, 07:58 PM
Broke EF's Avatar
We finally got around to checking the cam and it was all good. What else can it be, and what should we look at? Like I said my boss is a car guy who happens to be an electrical engineer that has a few oscilloscope's and knows how to use them. Is that the next step?
Sean
Old 02-15-2011, 08:12 PM
TunerGuy's Avatar
Did you try any of the broken sensors in another vehicle, to see if they were bad?
Old 02-15-2011, 08:34 PM
Dont have any access to another car.. Good idea though. I think i am going to replace the wires from sensor to ecu, put a new sensor in, and see what happens.
Thanks, Chris
Old 02-15-2011, 08:57 PM
joecar's Avatar
Sean
Yes, this is the next step... the waveform should look uniform, square, clean... like the blue waveform here:
Old 02-15-2011, 09:04 PM
joecar's Avatar
Warning:
to protect your boss's oscilloscope, always measure each waveform wrt to ground (i.e. connect all the probe grounds to chassis/battery ground and not to the sensor);
this is critical on multiple channel scopes that have each probe's ground connected to a common point.
Quick Reply: Cam position sensor keeps going bad?
