Racer's Lounge - Anyone have a crown (dental)?
West Texas Blues
10-13-2010, 12:31 AM
i got a crown on saturday and i haven't been able to chew on it since, the dentist said that might happen for a few days and i just want to know how long it took until you could chew properly
Super Speed
10-13-2010, 12:54 AM
I got a few in middle school and I could chew the next day, my first one was shiney and metallic my second one was white and enamel colored!
Yeah you shouldn't have to wait more than a few days before it starts to "settle" in. There is a chance they didn't make it properly...
Jon5212
10-13-2010, 07:43 AM
What do you mean you can't chew on it? Does it hurt? Or is your bite not lining up correctly? I've got one... but I need a root canal on the tooth it's on thats the only reason I can't chew on it cause it hurts like a SOB.
West Texas Blues
10-13-2010, 09:13 AM
my teeth line up fine, it hurts enough to make me wanna chew with the other side but it's not excruciating
Jon5212
10-13-2010, 11:30 AM
Most likely you need a root canal, why did you get a crown in the first place? Did you have a crack in the tooth?
92maro
10-13-2010, 09:29 PM
I have 5 root canal-crowns and 4 build up-crowns. None of them have given me issues past the 24 hour mark. you should probably look into a follow up.
Sharpe
10-13-2010, 09:50 PM
I have one. I was fine same day and he said I really should have gotten a root canal.
1FAST02FORMULAHAWK
10-13-2010, 10:01 PM
You need to return to the dentist, theyll take a grinder and file it down for you. Its profile is too high.
I had the same thing happen about a year ago
West Texas Blues
10-13-2010, 10:18 PM
my molar chipped during dinner some time ago, dentist said it's probably cuz i grind my teeth while i sleep (called bruxism) then he got in there and found decay, i'm definitely going back for a follow up
bayer-z28
10-13-2010, 10:20 PM
It was a while ago but yeah. Got a crown/bridge. The dentist ground it down a little to get my bite to match normally, but it just felt funny for the first week or two.
Jon5212
10-14-2010, 08:48 AM
Yup almost the same problem I have, I kept having pains, they couldn't see a crack in this molar but I know it was the right one... so they just ground it down and put a crown on it... now it hurts like a SOB if I even think about chewing over there. I'd ask the dentist he needs to do the job right free of charge.
Sneakyws6
10-16-2010, 12:14 AM
I have 7 crowns and a 3 tooth bridge. I have had at least that many root canals as well and have never had a issue outside of 24h from leaving my dentist office with any of my crowns.
Sucks growing up with weak enamel, on the bright side now I dont get cavaties since most of the problems teeth are all fake now...lol
