Syntheic trans fluid,who running it, good/bad...
Like the title say's,I've been running this since I put the headers in...Ever since then I've been having more problems with my trans then before the filter & fluid change...I aslo notice it smell's burnt,but the fluid still looks bright red and no shavings in the fluid???Thought's?
Anyone have an idea on why it smells burnt???
Syn in a 4t65e will make it start slipping. I run a mix of dex 6 non-syn, Coastal makes it(AutoZone), and something else. At least stick to just regular old dex 6. Don't worry this happens to our V-6 little borthers too.
-Mike
-Mike
Ironically in my GS I was running Royal Purple ATF. My diff broke and after fixing it I could not find enough Royal Purple ATF so I went with DEX and my trans lasted for 10k more and then messed up. Fluid turned brown and stinks now before was red. Just my own experience.
No problem helping out. I've already made this mistake so I know what happens when full syn. is introduced to the 4t65e. The trans. "should" go back to normal within a 100 miles after you change the fluid to Dex 6. If it doesn't then the friction plates are shot. Syn sucks for these transmissions...especially RP ATF and Mobile 1 fully synthetic.
-Mike
-Mike
-Mike
-Mike
My 10k miles spare tranny (in perfect condition) might be available if Dave @ TEP doesn't give me enough value in our barter deal for a valve body and soft parts.
Hopefully, you won't need it, but I just wanted you to know that a good one is available locally, if you need it.
Hi Dom,
If your willing to part way with it,how much you sell it to a Local So Cal Ls4 owner...you can PM me a price,and maybe we can work out a deal...Thanks for the help...
Dom
