Nitrous Oxide - Need some nitorus help.
View Full Version : Need some nitorus help.
c6 batmobile
10-13-2010, 05:34 PM
Ok I have yet another problem. Today I ran the car on the dyno so that I could get an accurate a/f ratio and just see all around what it was doing on the spray. Well the N/A a/f ratio was 12.3 a little rich but no biggie. On the spray the a/f ratio was 14.0:bs::barf:. That is not good. We had to shut it down early because that a/f is scary. So the shop thinks that I need a bigger fuel jet. Zex told me to use a 46 nitrous pill and a 28 fuel pill for a 100 shot. What do you think? I have some scans that I can post if necessary but they do not include the a/f ratio.
Quick Sh0t xMLx
10-13-2010, 07:29 PM
Damn, I know all the kits are different but NX told me .052/.033 for a 100 shot, that's what I ran when I had a 100 shot. That said the ratio seems decent and it shouldn't run that lean. Does your fuel solenoid work? My first guess would be it doesn't or goes on/off intermittently. I would pull both lines off the nozzle and check to see if the fuel solenoid is spraying any fuel.
c6 batmobile
10-13-2010, 07:34 PM
yeah I was told the fuel pill may be to small. I tested the solenoid before I put the lines in and it was spraying fuel and nitrous. I could check it again when I pull the line to change the pill.
It was also suggested that I may need a standalone. If so would a boost pump work? Like this one?
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=ZX&Product_Code=82020&Category_Code=
c6 batmobile
10-13-2010, 07:40 PM
Could the fuel rails possibly be getting starved? If so would an aftermarket set of rails help?
The car made almost 500 rwhp N/A without the nitrous so maybe Im getting close there?
waterbug1999
10-13-2010, 07:48 PM
What fuel pump u running? If ur running a single Walbro 255 then there is no doubt your running out of fuel.
c6 batmobile
10-13-2010, 08:10 PM
what ever came stock in my c6 vette. I know very little about the fuel system. So would a boost pump do or would I need something else?
waterbug1999
10-13-2010, 08:18 PM
If you got the $$, get a stand alone, then fix your NA tune and re-try the jets.
If you got the time and the know how, you can make your own, I did.
http://i279.photobucket.com/albums/kk151/waterbug19999/plumed.jpg
c6 batmobile
10-13-2010, 09:19 PM
yeah i dont have the time to try and fix this. I just need to figure out what I need to do to fix it. I am moving to japan soon and just want to fix it or get rid of the nitrous I guess. This is frustrating to say the least. I did a lot of reading and research and was sure that a 100 shot would work with my car.
Do you think a dry kit would perform better than a wet one? My injector duty cycle is only at about 68 percent max when running N/A.
Twotonefreak
10-13-2010, 09:26 PM
You need to get an accurate dyno tune by someone local and up the fuel jet some.
Best thing to do is put a fuel psi gauge on it and see what the fuel is doing on motor first and then on the spray.
waterbug1999
10-13-2010, 09:30 PM
So did you guys play around with the jets any?
c6 batmobile
10-13-2010, 09:37 PM
That isnt a bad idea. What type of gauge do you suggest using? Any idea on where to get one?
Not yet but this was my first plan of action. I need to order a few more.
waterbug1999
10-13-2010, 11:42 PM
To play it safe you might want to come down on the N20 jet to see if it will richen up for ya.
c6 batmobile
10-14-2010, 05:43 AM
Got it. Im only testing on the dyno for now so hopefully even If I have lean spikes its only for short durations while I get this figured out.
lordrazo
10-14-2010, 05:56 AM
i agree with waterbug1999
