alternator cooling duct interference?
Old 10-14-2010, 07:17 AM
nunan0219's Avatar
Default alternator cooling duct interference?
hey guys, i started puttin the accessories on my 79 t/a, and i'm getting significant interference that wont allow my alternator to bolt int he factory fbody position, because its hitting the engine cradle. anyone run into this issue?
Old 10-14-2010, 07:28 PM
nunan0219's Avatar
anyone?
Old 10-14-2010, 07:30 PM
sjsingle1's Avatar
the truck alt.........which i am running......does not have a cooling duct like the stocker......trim it as you need i say
Old 10-14-2010, 07:54 PM
eroc022's Avatar
using what accessories? fbody or truck or vette ? i have vette nothing interferes....
Old 10-14-2010, 08:09 PM
nunan0219's Avatar
fbody, its got this huge freakin coolin duct on the back.
only problem with cutting is that it will expose the diodes etc to possibly short circuit situation (expose electronics to the elements)
Old 10-14-2010, 08:37 PM
eroc022's Avatar
might have to notch the frame? or modify it with some heat and a hammer?
Old 10-15-2010, 01:09 AM
sjsingle1's Avatar
Old 10-15-2010, 01:10 AM
sjsingle1's Avatar
Old 10-15-2010, 01:11 AM
sjsingle1's Avatar
as you can see....there is plenty of room to trim if needed
Old 10-15-2010, 01:09 PM
71ANTICARB's Avatar
Cut off the duct trim it up and epoxy it back on.
Old 10-15-2010, 01:23 PM
nunan0219's Avatar
okay, didnt want to do it and hinder the performance at all if no one else has.
Old 10-15-2010, 01:44 PM
71ANTICARB's Avatar
Most other alts don't have that cooling duct because they have more air flow around them however in the fbody does have much room to allow enough air flow to the alt.
Old 10-15-2010, 06:22 PM
nunan0219's Avatar
cut the duct, epoxied it back and everything fits fine. close but fine.
Old 10-15-2010, 10:15 PM
71ANTICARB's Avatar
Old 10-16-2010, 09:29 AM
nunan0219's Avatar
yeah, i forgot i have a band saw in my basement (out of sight out of mind) but it worked well.
Quick Reply: alternator cooling duct interference?
