ob2 code P1626?
ob2 code P1626?
i have a 97 T/a A4.... it wont start and i get code "P1626 Theft Deterrent System - Fuel Enable Circuit" i hav already replaced the ignition switch, but its a security issue is there any way to bypass it? if not then how do i fix it? any input appreciated thanx.
If you want to fix it (provided you didn't ditch the lock cylinder):
http://shbox.com/1/pass_key.html
http://shbox.com/1/4th_gen_tech2.html#pass_key
If you want to bypass it:
http://shbox.com/1/vats_bypass.jpg
