Building motor... need HELP!!!
Old 10-15-2010, 02:13 AM
killerz97's Avatar
Default Building motor... need HELP!!!
Ok so I am a bit of a newb to all of this and I am mostly unsure of how extreme of a build I can go. Originally my goal was 383ci with forged internals(eagle most likely), Patriot heads (because of cost), and a fairly good size cam w/ 1.6 RRs. The car will be a pump gas street/strip car. I was told by a guy at the local speed shop that i couldnt go above 10.5 CR on pump gas but after reading I know this is untrue. I also thought about N20 in the future so if possible I might try to plan that into the build.
What heads should i run?
What cam should i run?
What CR should i look to run?
Keep in mind that my budget isnt infinite since I am a student?
I appreciate any and all feedback.
Thanks
Old 10-15-2010, 05:53 AM
RamAir95TA's Avatar
Thanks
The first and most important thing you should do is establish a budget, an actual dollar amount. I see you mention that it isn't infinite so that doesn't really narrow it down. Is there a target ET/RWHP/FWHP goal that you're looking for? Depending on a few things a stroker motor may not be what you need. Additionally, what current modifications do you have (drivetrain, exhaust, intake, etc.) as this will play a major part in your budget. Can't have the motor without the supporting modifications!
Old 10-15-2010, 07:08 AM
moehorsepower's Avatar
First off if you add up a budget, then have at least 1/3 to 1/4 more aside for incidentals. Look for "Good Used" parts. I know of one kid that built his entire motor with used parts for a fraction of the cost of new and ran great. Used speed parts go for cheap, Example, My Hooker Long tubes cost me $850.00, I sold them for $250.00 My cam was $325.00, sold for $75.00, Get it...One thing I would shy away from is used injectors, only because they tend to varnish up fast and by the time you send them out to get cleaned and flowed matched, you are not far away from new ones
Old 10-15-2010, 10:54 AM
killerz97's Avatar
Ok well heres what im planning to spend on parts:
eagle forged rotating assembly= $1200+
Patriot heads= $1000 heads come assembled
Cam= $350 if i cant find a used one
RRs= $300 Comp cams or Harland Sharp or Comp Cams 1.6s
Timing Chain= $100
Pushrods= $50 used set of trick flows
Oil Pump= $40 Melling
Injectors= idk probably go with 30lbs/hr
Fuel pressure regulator= used one for cheap
Old 10-15-2010, 10:57 AM
killerz97's Avatar
Also the car will be getting a converter, longtubes, CAI, and a TB
Old 10-15-2010, 11:11 PM
jaycenk's Avatar
Missing a gasket set unless the eagle kit comes with one
Use a stock fuel pressure regulator
Your rockers are missing guide plates unless you go with S/A + you need to make sure the push rods are the correct length
Missing Tune
Opti?
Water pump?
Machine work for the block?
Putting together the engine?
If the eagle kit is ballanced neutral you need to change to a neutrally ballanced fly or flex plate
Hub for keyed crank or have yours broched
Valve cover modifications
Lifters?
and what ever else you may need as far as oil filter, plugs, wires, coil, ICM, Sensors, and more than likley all radiator and heater hoses unless they are newer.
Old 10-16-2010, 08:28 AM
killerz97's Avatar
Ok yeah i agree with everything buy why stock fuel regulator? I will also be able to do all of my machine work at school as far as boring and honing the only thing i dont know about is the clearancing.
lifters= ls7 lifters
new water pump and opti will be in store thinking about doing the full msd kit
and whats the ICM?
Old 10-16-2010, 09:05 AM
95z28onjuice's Avatar
The patriot heads may be a great head over the stock lt1 head but there are way to many people selling used heads for a great price out there for you to buy those low end heads. you can get a set of like le2 or better heads for around 1000-1500. this is where you should spend a good deal on the heads. Then you can get a cam that matches the heads. Next unless you plan on 600+ rwhp why forged? this adds 2x the price on parts.
You could build a cast botton end with FORGED pistons
Good heads
Mtached cam
and a Nitrous kit and be around 500hp to the ground.
this would save you a ton of money and im sure you would be much better off with the power. a 355 can save you on machine work as well...
Check out www.cnc-motorsports.com great prices and tons of lt1 stuff.... i got almost everything from there
Old 10-16-2010, 09:30 AM
jaycenk's Avatar
ICM= ignition Control Modual
Stock fuel pressure because any tune done buy most anyone is going to want stock fuel pressure. Changing the fuel pressure throws off so many things in the tune its not funney and it wont make you more power. clearancing isn't hard at all but making sure rods don't smack the cam.... kind of important. I agree with 95z28onjuice. A 355 with the right piston, used AI or LE2 heads and the right cam will make good power. only thing is you would need to get a dyno tune with street testing to get it ***** on.
Old 10-16-2010, 09:52 AM
MattSapp95_T/A's Avatar
Yea save yourself the head ache and stick with a stock FPR for sure... I have had 2 aftermarket ones go bad on me...Aeromotive and Holley..put the stock one back on and been great ever since.....
I also agree with a budget 355 bottom end and AI or LE heads should make you very happy...
Matt
Old 10-16-2010, 10:10 AM
Wicked94Z's Avatar
i wish i had patriot heads on my motor
Old 10-16-2010, 10:18 AM
killerz97's Avatar
Ok the rotating assemblys through eagle only come with i beam rods until you go to the forged crank then they come with h beams. Will the i beams be enough they are only rated at 400 or 500 hp?
Old 10-16-2010, 10:22 AM
Wicked94Z's Avatar
the only way I'd be putting I beams in my motor is if they were billet. Yea H-beams are heavy, but for the price... the strength is unbeatable.
killerz97's Avatar
Ok everybody else is saying go LE or AFR why would you go with Patriots?
...Just wondering.
Old 10-16-2010, 05:15 PM
RamAir95TA's Avatar
...Just wondering.
He's being sarcastic. There are better choices than Patriot.
Old 10-16-2010, 06:29 PM
gregrob's Avatar
I agree that you should NOT build a stroker. It would get annihilated by a good running stock shortblock with heads n cam.
You don't have the budget for a properly built stroker
Old 10-16-2010, 09:04 PM
killerz97's Avatar
Ok well I think I'm going to run the forged -5cc flat top pistons either mahle or srp but I don't want to have to piece together a rotating assembly but I want to run the h beams I'm thinking
About A comp cams 280xfi is it too little for afr or ai heads.
Old 10-16-2010, 09:12 PM
jaycenk's Avatar
On the cam CALL Lloyd or AI. Have one of them order a custom ground based on the heads. Mahle pistons and I am not sure about No2 on a stock crank and rods so I leave that to gregrob or someone else. He loves spray
Old 10-16-2010, 09:48 PM
you caint even think of a camshaft until your pistons are ordered and head cc size is know so you can figure out the math on a good matched camshaft. your getting way ahead of yourself. get a SCAT FORGED I BEAM ROD WITH A Probe Forged piston and it will allow you to have more money for head and cam choice. Mahle,SRP,and JE are all sick pistons and unless you have 700+ budget for these kinda pistons i would still push you toward a TRW or Probe Forged piston with a scat rod and stock crank, 190 afr or 210 if money lets you. A custom cam for your car.Magunm rockers and harden pushrods.
Old 10-16-2010, 11:53 PM
What are your HP goals...Maybe you have already stated it and I missed it...
You would be surprised how strong the stock crank is so that may be an option too so that you can save money and not have to buy a complete rotating assembly...
For what its worth.....We had a set of Eagle SIR rods in a 383 Solid Roller motor that made well over 400hp through a TH400 with unlocked converter and a 12 bolt with 4.10 gears.... We were also spraying it out the hole with a 250 shot...turning 7000 rpms...
the guy that had it before us was spraying it with a 2 stage 400 shot through a 6 speed...
The motor is still running to this day getting abused weekly....motor is at least 5yrs old.....
now I am not saying that SIR are the best thing out there I am just giving a PERSONAL experience want to clear that up before I start getting bashed...
Quick Reply: Building motor... need HELP!!!
