Pacesetter ORY-pipe? (need ideas)
Everyone is aware of how crappy the pipe comes together at the Y. Mine was just as bad as the pics floating around here or if not worse.. Was thinking about putting an X-Pipe on and then duals from there. Or should i just go "true duals" all the way from the headers? I have heard that the X-pipe might be better so it will equalize the back pressure.. What do you guys think and suggest? Thanks
Originally Posted by jrp
custom Y and your current catback or true duals.
there are a few threads just on the first page that go over both.
summit and or jegs, or you can go the dr. gas route. mufflers depends on what you want but those can be found at jegs/summit.
