AFR 210s?
Old 10-16-2010, 05:32 AM
DTB_LS1's Avatar
Default AFR 210s?
I seen these heads mentioned a few times in this section but I can't find any info on them. I've tried searching and even tried AFR's website but nothing was listed for an lsx 210. Can someone fill me in and how would these heads compare to tfs 215s or prc 215s?
Old 10-16-2010, 05:55 AM
RJB01camaross's Avatar
The AFR 210 heads replaced the AFR 205 heads. As I have seen posted they are intended for a 3.90 bore (LS1). I have not seen a comparison of the three but I am they all have there place in the right combination. If you ordered the AFR 205 heads off their site you would recive the AFR 210 heads.
Old 10-16-2010, 06:13 AM
mrx8200's Avatar
Thanks for clearing that up. I thought that people saying were 210 were just referring to the 205. How new are they?
Old 10-16-2010, 12:56 PM
DTB_LS1's Avatar
Yes how are they different from the 205s?
Old 10-16-2010, 01:29 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Complete redesign of the intake port....
Similar chamber and exhaust port
I will post flow numbers on Monday....don't have access to the info now.
We took a really good working formula and made it even better....bottom line
-Tony
Old 10-16-2010, 01:37 PM
camz28arro's Avatar
Here's the flow data from one of Tony's previous posts. Crazy numbers at .400-.500
INTAKE
Lift....AFR 205...AFR 210
.200......140.........153
.300......200.........214
.400......251.........262
.500......281.........293
.550......292.........300
.600......298.........302
EXHAUST
.200......112.........124
.300......170.........178
.400......203.........214
.500......221.........227
.600......230.........237
Old 10-16-2010, 03:02 PM
mrx8200's Avatar
I can only imagine how much power under the curve these things will have! Wow, gotta put these on my wish list.
Old 10-16-2010, 06:13 PM
garygnu's Avatar
if you buy them get the cam from Tony M.
Old 10-17-2010, 03:24 AM
mrx8200's Avatar
Do these heads have any driveability difference from the 205's? Btw anyone have any mpg numbers with these or the 205's and a mild cam?
Old 10-17-2010, 04:15 AM
camz28arro's Avatar
The 205's supposidly increased gas milage by 1-2mpg so I would think the 210's will be the same if not a little better also. A mild cam might offset the set of heads though by 2mpg.
With PRC heads, a 3200 A4, and tr224 I still get a 20.0mpg average
Old 10-17-2010, 04:37 AM
mrx8200's Avatar
Nice well H&C being MPG neutral or even a little worse isn't that bad. Just would have to keep the right foot off the ground. That's where you'd lose the MPG. I drive almost 100% city so need to keep low end torque. These heads look like they'd do wonders for that.
Quick Reply: AFR 210s?
