figured that since this was the hybrid section
Old 10-17-2010, 11:54 AM
baron's Avatar
Default figured that since this was the hybrid section
i'm going to put a SBC in my 89 mustang... i'm sure people on here have done this but havnt found any threads with a parts list?????
thanks
Old 10-17-2010, 04:09 PM
chuckd71's Avatar
Do you mean old-school SBC? Probably have more luck on a mustang forum I would think, I know I've read about people doing this. People use ford rear ends with sbcs all the time, so I bet you could just mimic those setups, make some motor mounts, get a driveshaft cut and throw it in there. Complete speculation on my part though. No idea how you'd wire it up.
Old 10-17-2010, 06:29 PM
Marcello7x's Avatar
Parts list will include all the acc, motor/trans, motor mounts, tranny mounts, custom cut drive shaft, and maybe a conversion u joint to mate up mix matched parts.
Just swap iin an lm7, i've seen full pullouts for around 1k All you need to do is install it, remove vats and turn the key.
