ls7 lifter part number
I have a failed ls7 lifter (1200 miles and a overrev). all the others are fine, just got a plunger stuck holding one open. Does anyone know the part number for individual ones? I dont see the reason to replace all 16 since im only having a problem on one cylinder
Thanks in advance
Thanks in advance
LS1Tech Premium Sponsor
Try 17122490.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
GmPartsDirect.com lists this as a set of 8 lifters for cost of $29.64, List $50.98. Jon at Texas Speed can you verify that this is indeed an LS7 Lifter part Number?
Correction, They are indeed 29.64 a piece when you go to checkout!!! so what is the part number for the kit for 16 of them thats only $139?
