starter and alt wiring question...
Old 10-18-2010, 09:11 PM
67 LS1 Vert's Avatar
Default starter and alt wiring question...
I'm running the MSD 6010 box now. What are you guys doing to wire up the starter, and alternator? I heard that the starter has some sort of magnetic solenoid that makes it run after you let off the key.
Details would be very helpful.
Thanks
Old 10-18-2010, 10:11 PM
bovey's Avatar
Hey,
Your question is very general. Figure out what you have like:
What LS engine/starter.
What style of alt.
Do some searches, there are plenty of posts on these subject. One that you will not find, due to how it's named is my post called "electrical issue". It turned out to be a alt wiring problem... it should get you going.
Actually, here.
https://ls1tech.com/forums/conversio...cal-issue.html
Again, figure out what you have and do some searches first. Everyone here is great, but you need to do homework first.
Cheers,
Bovey
Old 10-18-2010, 10:13 PM
bovey's Avatar
Oops. Just noticed your tag was LS1 vert... guess I shoulda done my own homework...
good luck.
Old 10-18-2010, 10:15 PM
I would think I know what I have and thought it would be pretty obvious with my screen name stating what type of engine.
