Headlight upgrade?
Headlight upgrade?
Ok, id like to upgrade my headlights. But i have no idea how the whole HID thing works, or how to upgrade them, or how to do the conversion. Im more mechanically inclined. I dont want the projectors because their really expensive (I saw a plug and play kit for 700) What do you guys have and where did you get them?
I have a 95 formula, and Ive been pondering the same thing. After doing some research, the 94-97 s10's use the same headlight as our birds, so I figure just use the euro housings
http://www.lmctruck.com/icatalog/cst/full.aspx?Page=66
and a universal HID kit off of fleaBay and call it a day, thats about the cheapest option that I can see, and thats my plan.
I just put the H4 5000k HID's in my '95 formula and love them. Nice to actually be able too see now!
Got everything off Ebay. Total cost $70.
http://cgi.ebay.com/ebaymotors/hid-k...Q5fAccessories
http://cgi.ebay.com/ebaymotors/77-97...item3cb102de3d
http://cgi.ebay.com/ebaymotors/HEAVY...item5ad78435fb
Any questions ,just ask!
They do light up the road well and on a two lane road they also light up quite a bit of the side of the road. For me, it is great because I can see deer on the side of the road better.
The install is pretty simple, there is a nice spot for the ballast's to the inside of the headlights. I used the supplied double sided tape and a self tapping screw in each one. The hardest part was splicing the wires for the upgraded socket and that was easy also. I also spiced the "city light' wires into the parking lights,so when I turn on headlight switch and back to parking lights, the city lights stay on. I used 194 white leds for those.
Use good connectors and heat shrink on the splices.
Following this thread also. I don't want to spend a whole lot of money for a simple set up. Want the best lighting for the best price, don't want blue light or none of that jazz, just much better than stock lighting
If either of you have a trans am you will have to modify your stock housing, which is simple, or buy a housing from somewhere like eurolights.com.
880 is the fogs for both trans am and camaro.
Not sure what the low beam camaro headlights is, a simple search will find it easily.. iirc its 9005 but don't take my word, check it.
For a trans am it depends on if you make your own housing or buy one from eurolights. If bought from eruolights just get whatever bulb type comes with it. If you make your own then you can just use a normal h4 or whatever.
You both owe me major, I typed all this from my phone.. basically one huge text msg, I hate doing it. Lol
Thanks Lemons for the text!
I don't see the housings on there sight. What is the process with modifying the ones on a TA (99).
Sorry for all the ?'s, but Im real ignorant when it comes to headlights, sealed beam, no sealed beam, halo's, projectors all that mumbo jumbo.
I really don't want to be a specialist on all of it either, I just want brighter headlights.
About the only thing I capisce about it all is to stay 6000 or lower to not get the bluish look.
If you can't find it I will get on my computer tomorrow and get you all the links you need with step by step directions. You need the same part number as stock for the eurolight housing, as said it is all in the write up.
Once you buy your housing or make them, which I will show both tomorrow, and install them it will all come together.
I would recommend 4k if you don't want blue. 6k is still pretty blue, I will show you a pic of my fogs tomorrow they are 35w 6k.
Also forgot to add you will need the hid relay ddm offers.. it is only like 12 bucks but you will appreciate it very much.
Ok im having a problem. Yesterday it said they would be able to ship 10-27-10 (today) now it says 11-2-10. So im looking at this kit:http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
Seems to be in stock. But i still dont know what i need as far as H1 H2 etc, im guessing i need the low and high beam. Also whats all these error code eliminator, HID harness, and adaptor cable options, do i need any of those. I really appreciate your help Lemons, thanks.
I was looking at these housings. It seems like it already comes with a bulb though
http://cgi.ebay.com/ebaymotors/4x6-H...Q5fAccessories
I couldnt find any housings on eurolights.com. Personally i dont like how their website is setup.
