Adjusting for larger rear tires?
Has anyone been able to adjust for larger rear tires so the ABS,Brake lights don't come on. I want to run some drag radials that are only availabel in larger sizes? Thanks!
I have a 2002 Formula LS1 A4
The ABS light will only come on if there is a 2 or more inch difference in tire height. The ABS is something you can not adjust with a tune you usually live with the light or remove the bulb
