TR224 to 229/232? Will it fit?
Old 10-21-2010, 07:51 PM
camz28arro's Avatar
Default TR224 to 229/232? Will it fit?
Wanting a little more power, would a custom eps lobed 229/232 .585/.588 113+3 fit with 61cc 243 heads and stock gaskets? Also would hoping for 20rwhp with the prc heads be reasonable?
Cam only has 4.5 degrees of overlap at 0.050 and only slightly more lift/duration.
Old 10-21-2010, 08:51 PM
SSPerformance's Avatar
hard to say need to mesure your PTV
Old 10-22-2010, 07:30 AM
camz28arro's Avatar
"The LS6 heads do have slightly better performance on the top end. If you're planning on spending alot of time in the higher RPM's, they'll treat you right! As for milling and gasket selection. My gut says you'll be fine with the .040" gasket and milled as much as .010"....but you'll for sure want to check it before you start it up!"
Through some searching I fould this, The Cometic is worth 13 thousands + .10 thousands milling, is about the same mine are milled (supposidly 24 thousandths) This guy was running a TSP 233/239 112 cam.
I just don't want to shell out any money if everybody thinks there isn't enough room for the above cam I mentioned.
Old 10-22-2010, 09:27 AM
LSX Mechanic
Damian's Avatar
You'll have PLENTY of room w/ 61cc. I've ran bigger cams than that on a 59cc head.
Run it.
Old 10-22-2010, 11:00 AM
camz28arro's Avatar
Thanks Damian, I'll still check before starting anyways if I do this.
Old 10-22-2010, 11:08 AM
TooLateVTEC's Avatar
My heads are 62cc with an .045 gasket and running a 230/236 .591/.601-112 cam with lots of room.
Its good to check but it should have plenty of room.
Old 10-22-2010, 11:15 AM
camz28arro's Avatar
Thanks guys, I also just found this searching:
"with 59cc 243 heads largest cam i've seen run is speed inc. SI5v2 231/237 .617/.607 112"
