what arp head studs for 370 iron block
Old 10-22-2010, 08:13 AM
TermnEatr's Avatar
Default what arp head studs for 370 iron block
I know there's diff sizes what size do I need for my iron 370?
Old 10-22-2010, 10:04 AM
KCS
Moderator
KCS's Avatar
I depends on the year of your block. The kits for the newer blocks have all the headstuds the same length (except the tiny 8mm diameter ones). The kits for the older blocks have two longer studs for each side.
Old 10-22-2010, 10:10 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
^ Backwards. The older bolts are 2 short ones and the rest are long. The 2 short ones go at the ends of the block/head. Really long. The new ones are all short.
Old 10-22-2010, 10:21 AM
KCS
Moderator
KCS's Avatar
My bad, you're right.
Old 10-22-2010, 10:55 AM
TermnEatr's Avatar
k I appreciate it
Old 10-22-2010, 11:04 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
If they are the long/short variety all the way to 2003 then they are
234-4316
If they are all the same length then it is an 04 and up block and it is
234-4317
