valve stem height
LS1Tech Premium Sponsor
Installed height typically runs around 1.790"-1.800" on a stock head and stock valve....and of course that is altered any time you run different spring seats, shim under those seats, different retainers, etc!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Isn't that the spring installed height? I was referring to the total length of valve stem above the aluminum of the head to maintain proper lifter preload after a valve job. THANKS
Sorry, I just skimmed quickly and saw installed height....that is correct for spring installed height. I do not have the number for tip height in front of me, but might be able to get it for you if these phones calm down a bit later!
__________________
