WTT GTO for Fbody or 6.0 GTO
For Sale:
1998 Pontiac Firebird Trans Am
LS1 5.7 V8
Auotmatic 4L60E Transmission
Black Exterior
Dark Grey Interior
T-Tops
Power Windows
Power Door Locks
Tinted Windows
(5% Rear Hatch Window/ 5% T-Tops/ 35% Side Windows)
AM/FM CD Player
Clean Title
90,000 Miles on the chassis
33,000 Miles on the Engine/Transmission
2,500 Miles on all the Non-Stock Performance Add-Ons
Engine:
New F.A.S.T 102mm Intake Manifold $1050.00
New P.T.M. 102mm Throttle Body $325.00
New Patroit Performance Stage 2.5 LS6 "243" Ported and Polished Heads w/Dual Valve Springs up .650 lift $1,300.00
MTI S1 Camshaft 244int Dur/244ext Dur, .612Int lift/.612ext lift, 112 LSA $250.00
New Trickflow Chromoly Pushrods $120.00
New GM Head Gaskets $75.00
New Oil Pressure Sending Unit $75.00
New Crank Sensor $35.00
Pacesetter Long Tube Headers $250.00
New Powerbond Underdrive Pulley $225.00
New LS2 Fuel Rail Kit $250.00
FMS 42lbs Injectors $225.00
New SLP Air Lid Kit $100.00
New NGK TR-55 Spark Plugs $35.00
Oil Changed with Royal Purple and has Mobil 1 Oil Filter
New Granatelli Motor Sports 255 lph Fuel Pump $130.00
New AC Delco Fuel Filter $6.00
MagnaFlow Muffler straight Pipe with a Manual Cut-Out if needed to a ORY-Pipe $300.00
Transmission:
New Fully Rebuilt 4L60E with Shift Kit Under 100miles $1,300.00
New Yank SS4000 Torque Converter $830.00
New B&M Transmission Cooler $100.00
Drivetrain/Suspension/Wheels and Tires:
New UMI Adjustable Torque Arm Tunnel Mounted with Safety Loop $415.00
New BMR Non-Adjustable Lower Control Arms $120.00
New Competiton Engineering 3 Way Drag Shocks $95.00
New Motive Race Competition 3.73 Ring and Pinion with all new bearings $350.00
Tuning:
Tuned at All Out Performance in Fresno CA. $700.00
Did a 2002 PCM Swap ($75.00 for the PCM) with all wiring done so a wider tuning table could be done and is great for a Nitrous build and makes things alot easier.
The Trans Am Dyno Numbers are with a Speed Density Tune and the numbers are unlocked, so if locked would be easy 50-75rwhp more on the dyno graph, but i'm not a dyno queen and looked to make the car drive and perform great.
427rwhp/371rwtq on a unlocked torque converter pull!!!!! THATS GREAT NUMBERS ON UNLOCKED and on a N/A Setup!!!!!
I have all receipts to all the purchases made in the last 3-4 months on all the parts listed. Most which were purchased from Summit Racing or Texas Speed Performance.
Car is in good shape just has a 1 1/2 inch crack in the fiberglass on the passenger side front fender.
I have ALL the A/C equipment to be put back on if needed, i just took off for weight reduction.
Car Has Gone 11.6 with a 1.6 60ft 115mph at Sacramento Raceway on 10-20-2010 Will be easy 11.0-11.2's with new setup and with a 4.10-4.30 gear swap high 10's.
Asking Price is $11,500 o.b.o was asking $12.5k
"PM" me with offers
No test drives unless money is shown up front and don't low ball with any dumb offers not in a hurry to sell!!!!
Possible Trades:
01-02 Camaro SS 6spd
64-72 Nova
67-69 Camaro
70-73 Camaro
86-87 Grand National
70-73 Firebird
70-75 Chevrolet Silverado 4x4 Lifted (Automatic Only)
65-73 El Camino
94-96 Toyota Supra
64-71 Chevelle
94-96 Ford F-250 or F-350 Powerstroke 4x4 (Automatic Only)
and if trade is less value then mine expect to put cash on top of trade.
Dyno Tuning Video 8-25-2010:
http://www.youtube.com/watch?v=6rnRkOivZyE
11.6 run with a 300lb driver and on a wednesday night drag night with sorry track prep and on the street exhaust setup and street suspension setup. 10-20-2010
http://www.youtube.com/watch?v=0HstdTjYWiQ
LS1 5.7 V8
Black Exterior
Dark Grey Interior
T-Tops
Power Windows
Power Door Locks
Tinted Windows
AM/FM CD Player
Clean Title
Engine:
Transmission:
Tuning:
"PM" me with offers
Possible Trades:
64-72 Nova
67-69 Camaro
70-73 Camaro
70-73 Firebird
65-73 El Camino
94-96 Toyota Supra
64-71 Chevelle
